Work done in a Gravitational Feild of a Hemisphere
The correct formula for the work done by the gravitational field force on a mass 'm' at the center of a hemisphere with mass 'M' and radius 'R' is -3GMm/2R. The mistake you made was using the center of mass of the hemisphere instead of the center of the base of the hemisphere in your calculation. In summary, the correct formula for the work done is -3GMm/2R, not 8GMm/3R.
Himanshu
67
The problem concerns with the work done by the Gravitational Feild force exerted on a mass 'm' kept on the center of the base of a hemisphere of mass "M" radius "R".
The way I did it was, first I found the Center of Mass of the hemisphere which is 3R/8. Next I used the concept => Work done= -Potential Energy.
PE=-8GMm/3R
So Work done would be= 8GMm/3R
Work done by Gravitational Feild force is -8GMm/3R
But the book says the answer is -3GMm/2R
Where am I wrong . Please Help!
Your first formula only applies to a full sphere.
Your method is wrong.
Your calculation for the work done by the gravitational field force is correct. However, the book's answer of -3GMm/2R may be referring to the work done by the force of gravity on the mass m as it moves from the center of the base of the hemisphere to the top of the hemisphere. This would involve using the equation W = mgh, where h is the height from the center of the base to the top of the hemisphere. This would result in a work done of -3GMm/2R, as given in the book. It is important to clarify which specific force is being referred to in the problem and in the book's answer.
Related to Work done in a Gravitational Feild of a Hemisphere
1. What is the formula for calculating work done in a gravitational field of a hemisphere?
The formula for calculating work done in a gravitational field of a hemisphere is W = mgh, where W is the work done in joules (J), m is the mass of the object in kilograms (kg), g is the gravitational acceleration in meters per second squared (m/s^2), and h is the height in meters (m).
2. How does the work done in a gravitational field of a hemisphere compare to other shapes?
The work done in a gravitational field of a hemisphere is half of the work done in a gravitational field of a full sphere. This is because only half of the sphere's surface area is exposed to the gravitational force, resulting in half the work done.
3. Does the radius of the hemisphere affect the work done in its gravitational field?
Yes, the radius of the hemisphere does affect the work done in its gravitational field. The larger the radius, the larger the surface area, and therefore the larger the gravitational force and work done.
4. Can work be done in a gravitational field of a hemisphere without an external force?
No, work cannot be done in a gravitational field of a hemisphere without an external force acting on the object. The gravitational force alone cannot do work on an object, it only provides the potential for work to be done.
5. How can the work done in a gravitational field of a hemisphere be used in real-life applications?
The work done in a gravitational field of a hemisphere can be used in real-life applications such as calculating the energy required to lift objects, understanding the mechanics of roller coasters and other rides, and determining the stability of structures built on a curved surface.
