Work done in adiabatic compression
In summary, the equation I know for adiabatic work is W = P1V1((V1/V2)ϒ-1 - 1))/ϒ-1, but this involves ϒ, but I can use ϒ = Cp/Cv = Cv+R/Cv = 1 + Cv/R, does this seem correct? But I still have a P1Homework Statement.
  • #36
This problem is really straightforward if one chooses as the "system" the combination of gas plus piston. Then, from the first law of thermodynamics, we have: $$dU=(nC_v+C)dT=-PdV=-\frac{nRT}{V}dV$$where n is the number of moles of gas, Cv is the molar heat capacity of the gas, and C is the heat capacity of the piston.
Likes TSny, Lord Jestocost, haruspex and 1 other person
  • #37
Ehm, is it ok to say that the ##dU## of piston is just ##CdT##?
That leads to a nice and neat separable ODE btw, we can find T(V) relatively easily...
  • #38
Sure. It is considered an incompressible solid.
Likes Delta2
  • #39
Yes. This leads to a very simple result for the work done on the gas during the process in terms of the overall temperature change ##\Delta T## for the process. Maybe this is what they want. So, perhaps ##dT## in the statement of the problem is meant to be ##\Delta T##. I don't know.
You can also use Chestermiller's equations to derive the relation between ##T## and ##V## during the process. Then you can express the work done on the gas in terms of the initial temperature and the initial and final volumes of the gas. This is what I had in mind in post #17.
Likes Delta2
  • #40
Yeah maybe it was that simple, I just wasn’t sure if they wanted me to use nm as it wasn’t in the variable list
Likes TSny
