Work done on a force using dot product
In summary, Webassign says that the answer is incorrect because the displacement in this case is only in the x direction and not the y and z directions.
TrippingBilly
27
The question with all the info is:
A force F = (6x i + 5y j) N acts on an object as it moves in the x direction from the origin to x = 5.04 m. Find the work (work = integral of F (dot product) dx done on the object by the force.
I am confused as to what dx would be in this equation, and how to find it.
The work that I've done so far is (using an equation from my book) W= F(dot product) change in x. First off, will this equation even work? Its a little different than the first one I wrote. But second, since the dot product is used for two vectors i wrote the change in x part of that equation as a vector <5.04, 0>. So taking <5.04, 0> (dot product) <6x, 5y> = 30.42x. I don't think there should be a variable in my answer so I tried to answer with 30.42 but that isn't correct.
I have a feeling that I am far off base with what I've done so far. Please help, thank you.
The displacement element is just "dx i", since it only moves in the x direction. Now integrate F*(dx i) over the range of x.
I don't know what "dx i" stands for, or how to calculate it. Is it the displacement in the x direction?
Yes, that's all it is. Displacement is a vector; the element magnitude is "dx" and the direction is "i". Now take the dot product and integrate.
In general the displacement would be: dx i + dy j + dz k
But in this case, it only moves in the x direction.
Thanks for the quick replies DocAl!
Here are my calculations:
F=<6x, 5y> delta x = <5.04, 0>
F*delta x = 30.42x
Integral from 0 to 5.04 of 30.42xdx = (30.42x^2)/2 from 0 to 5.04 = 386.23
Webassign says that this is incorrect, and that my answer differs from the correct one by 10% to 100%
Ive triple checked my calculation, I'm not sure where my error is..
Your error is putting dx = 5.04. 5.04 is the range of x; dx is an infinitessimal element along the x axis. You must integrate over the range of x. Do this:
F = 6x i + 5y j
ds = dx i
What's F*ds? First figure that out, then integrate from x = 0 to x = 5.04.
F * ds = 6xdx
So the integral over the range of x is 3x^2 from x=0 to x=5.04 so the answer is 76.2048 right?
Looks good to me.
Thanks very much! I appreciate it
FAQ: Work done on a force using dot product
What is work done on a force?
Work done on a force is a measure of the energy transferred to an object when a force is applied to it and causes it to move.
How is work done on a force calculated?
The work done on a force is calculated by multiplying the magnitude of the force by the distance the object moves in the direction of the force, using the dot product formula.
What is the dot product in relation to work done on a force?
The dot product is a mathematical operation used to calculate the work done on a force. It involves multiplying the magnitude of the force by the cosine of the angle between the force vector and the displacement vector.
Why is the dot product used to calculate work done on a force?
The dot product takes into account the direction of the force and the displacement of the object, which is important in determining the work done on the force. It also allows for the calculation of work done in three-dimensional space.
How is the dot product related to the concept of energy?
The dot product is related to the concept of energy because it represents the transfer of energy from the force to the object. The dot product formula, force multiplied by displacement, can also be written as the product of force and the component of displacement in the direction of the force, which is equivalent to the work-energy theorem.
