Work done on changing direction of a tennis ball
In summary: I should have said "I don't believe there is any need for energy to go into making the noise of the impact."As a result, the ball's kinetic energy is unchanged. Therefore, the work done by the tennis player is zero as the change in kinetic energy is also zero.In summary, based on the equations for momentum and work, it can be concluded that the work done by the tennis player to reverse the direction of the ball is zero. This is because, in an elastic collision, there is no change in the ball's kinetic energy and the force applied by the racket does not move through any distance. Therefore, the net work done on the ball is zero. Additionally, any energy lost in the collision would be due to
Chris0101
[/B]
A tennis player strikes an incoming tennis ball of mass m and speed v such that the ball leaves the racket at speed v as well. How much work was done by the tennis player to reverse the direction of the ball? Explain. Did the tennis player do any negative work?
##W = Fx = 1/2 mv^2##
Here is my attempt with the use of calculus and differential equations:
##F = ma = mv dv/dx##
##Fdx = mvdv##
Integrating both sides, where the left integral is integrated from 0 to x and the right integral is integrated from v to -v, yielding:
##Fx = 1/2 m(-v)^2 - 1/2mv^2##
##Fx = 1/2mv^2 -1/2mv^2##
##Fx = 0##
Mathematically, it appears that the work done by the tennis player is zero if the magnitude of velocity is equal to that of the starting velocity.
I would assume that this is correct because because work would be greater than zero if the ball leaves the racket at a greater speed than it arrived at the racket and alternatively, work would be negative if the velocity decreased leaving the racket.
I need some clarification with regards to this, any insight would be greatly appreciated.
You don't need calculus - you already know the equations for momentum and work.
... that's not too bad.
Work is the change in energy ... since the kinetic energy of the ball is unchanged during the collision we can conclude that the net work done on the ball to change it's direction is zero (not counting energy that changes the temperature of the ball, make that thwacking noise, swing the racquet etc.)
However, Work is also force times distance ... the ball clearly experiences a force (it's momentum changes) which acts over some distance (as the ball and racquet squash together)...
Simon Bridge said:
the ball clearly experiences a force (its momentum changes) which acts over some distance (as the ball and racquet squash together)...
Not necessarily. If the collision is completely elastic then it must be the case that the racket was held stationary. If we take the racket to be rigid, the force applied by the racket does not move through any distance. If we allow for elasticity in the racket, it first does negative work then an equal quantity of positive work. The internal motion of the ball in squashing against the racket is its own affair.
Both the racquet and ball deform during the collision though. This is a necessary part of the operation of both objects: it's how they are designed to behave.
The extension to positive and negative work that results is what I was hoping the OP would come up with ;)
If it's a racket instead, then there will surely be substantial energy loss in making so much noise :D
Yes, but you wrote
To me, that implied the racquet doing net work on the ball.
If it is completely elastic, whether by virtue of the ball's or the racquet's elasticity or both, the racquet does no net work on the ball. There may well be no net change in position in space of point of contact during contact.
Well hit, sir.
Related to Work done on changing direction of a tennis ball
1. What is the definition of work done on changing direction of a tennis ball?
The work done on changing direction of a tennis ball refers to the energy required to change the direction of the ball's motion. This can be achieved through a force acting on the ball, such as a player hitting or throwing the ball.
2. How is the work done on changing direction of a tennis ball calculated?
The work done on changing direction of a tennis ball is calculated by multiplying the force applied to the ball by the distance over which the force is applied. This can be represented by the equation W = F * d, where W is work, F is force, and d is distance.
3. What factors affect the amount of work done on changing direction of a tennis ball?
The amount of work done on changing direction of a tennis ball can be affected by various factors such as the mass of the ball, the velocity of the ball, the angle at which the force is applied, and the surface on which the ball is moving.
4. How does the work done on changing direction of a tennis ball impact its trajectory?
The work done on changing direction of a tennis ball directly affects its trajectory. The greater the work done, the more significant the change in direction will be. This is because a larger amount of energy is transferred to the ball, causing it to move in a different direction.
5. Can the work done on changing direction of a tennis ball be negative?
Yes, the work done on changing direction of a tennis ball can be negative if the force applied to the ball is in the opposite direction of its motion. This means that the energy is being taken away from the ball, causing it to slow down or change direction in the opposite direction.
