Work done on the centre of mass and kinetic energy of system
In summary: But you undoubtedly have to work through the details yourself.In summary, the work done on the center of mass of a system is equal to zero if there are no external forces acting on the system. However, if there are internal forces present, the total kinetic energy of the system will change. This is because the total kinetic energy includes the individual kinetic energies of each component, while the kinetic energy of the center of mass only considers the overall motion. When applying an external force on a system with internal forces, it can be ambiguous whether the work is done on the center of mass or on the individual components. It is important to consider the details and definitions of "work" in order to accurately apply the work energy theorem.
NoahCygnus
96
If we have two objects forming an isolated system and their centre of mass is ##X_{com}##, we know by work energy theorem that work done on centre of mass will be ##\int F_{ext}.X_{com}= 0## as no external force is acting on the system. However, if there is internal forces between the objects, there will be a change in kinetic energy of both the objects and as a result it will change the kinetic energy of the system. Why is the work done on centre of mass not equal to the change in kinetic energy of the system?
Kinetic energy does not have to be conserved but total energy does. The total energy will remain constant for the closed system.
The total kinetic energy of the system includes the kinetic energy of each component separately. If we ignore rotation and thermal energy for the moment and consider a simple system with two masses, m1 and m2, the figure for total kinetic energy is: $$KE=\frac{1}{2} m_1 v_1^2 + \frac{1}{2} m_2 v_2^2$$
The kinetic energy considering only the motion of the center of mass is given by: $$KE=\frac{1}{2}m_{tot} v_{CM}^2$$
WIth a bit of algebra, it can be shown that the former is always at least as large as the latter.
If you apply an internal force, accelerating mass 1 in one direction and mass 2 in the opposite direction, the center of mass does not change velocity. The center-of-mass kinetic energy remains constant. But the total kinetic energy changes.
Hint: Introduce CM and relative coordinates and rewrite the kinetic energy in terms of those:
$$\vec{X}=\frac{m_1 \vec{x}_1 + m_2 \vec{x}_2}{m_1+m_2}, \quad \vec{r}=\vec{x}_1-\vec{x}_2.$$
Apologies for the late reply. If we apply external force on the two particle system which are exerting a force on each other, in such a case, when we say the external force does work on the system, do we mean the external force does work on the center of mass of the two particle system, ## W_{ext} =\int \vec{F_{ext}}.d\vec{r_{com}} ##? Or will the work done by the external force be equal to the sum of the individual works it does on the two particles, ##W_{ext}= W_{ext, particle 1}+W_{ext, particle 2} = \int \vec{F_{ext}}.d\vec{r_{1}} + \int \vec{F_{ext}}.d\vec{r_{2}}##?
One might mean either thing. It is ambiguous. If my [forty odd years ago] experience is any indication, classroom teachers and textbooks are not careful in describing how "work" applies to rotating or non-rigid systems. [Calling @Doc Al -- I know he has ideas on this]
Often, one is uninterested in details and is only concerned about the resulting bulk motion of the system. In which case "center of mass" work is determined by multiplying the applied force by the motion of the center of mass. This approach kind of works, but it causes problems if you expect the work energy theorem to be useful as a statement about conservation of energy.
Sometimes one is interested in the picky details. In which case the work is determined by multiplying the applied force by the motion of the exact point(s) on which the force acts.
Well, then you should read more theoretical-mechanics textbooks. Almost all of them get the spinning top (rigid body) and thus rotation energy right.
FAQ: Work done on the centre of mass and kinetic energy of system
1. What is the definition of centre of mass?
The centre of mass is defined as the point in a system where the entire mass of the system can be considered to be concentrated. It is the average position of all the mass in the system.
2. How is work done on the centre of mass of a system?
Work is done on the centre of mass of a system when a force is applied to the system and the centre of mass moves in the direction of the force. This is because the displacement of the centre of mass is in the same direction as the force, resulting in work being done.
3. What is the relationship between the work done on the centre of mass and the kinetic energy of a system?
The work done on the centre of mass of a system is directly related to the change in kinetic energy of the system. This is because work is the transfer of energy and in the case of a system, the work done on the centre of mass results in a change in the system's velocity, thus changing its kinetic energy.
4. Can work be done on the centre of mass of a system without changing its kinetic energy?
Yes, it is possible to do work on the centre of mass of a system without changing its kinetic energy. This can occur when the force applied to the system is perpendicular to the direction of the displacement of the centre of mass. In this case, the work done would result in an increase in the system's potential energy.
5. How does the distribution of mass affect the work done on the centre of mass of a system?
The distribution of mass in a system can affect the work done on the centre of mass. If the mass is more concentrated towards one end of the system, then the centre of mass will also be closer to that end. This means that a force applied at that end will result in a smaller displacement of the centre of mass, and thus less work will be done on it. On the other hand, if the mass is evenly distributed, a force applied to any point will result in a larger displacement of the centre of mass and more work being done.
