Work done pumping air into a bottle
In summary, the conversation discusses the process of pumping air into a bottle with a constant volume and temperature, and the goal of calculating the work done during this process. Various attempts to find a general expression for the work are discussed, including using the ideal gas equation and considering the number of moles and change in density. The conversation also explores the idea of the external work done by the pumping process, and suggests solving a simpler problem to better understand the concept. Ultimately, a formula is derived for the work done in an isothermal process, and a similar formula is discussed for an adiabatic process.
Funky_Sp
Hi there, i am struggling with the following problem. Air is pumping into a bottle with volume V and pressure Pi until it reaches a final pressure Pf. The temperature remains the same during the process and the gas is an ideal one.
We have to calculate the work that is done.
I am not quite sure how deal with it, since the volume is constant i cannot use the trivial expression [tex]W=\int_{Vi}^{Vf}pdV[/tex]
I tried to derive an equation for the work, depending on the change in density and number of particles but I don't have enough information for that. My next attempt was to use the general expression for the work, [tex]W=\int_{i}^{f}Fdx[/tex] but after a little calculus I am coming back to the first equation. My last attempt was to proceed with that , and state, that since the gas is an ideal one then [tex]p_{i}V_{i}=p_{f}V_{f}\Rightarrow \frac{p_{i}}{p_{f}}=\frac{V_{i}}{V_{f}}\Rightarrow ln\frac{p_{i}}{p_{f}}=ln\frac{V_{i}}{V_{f}}[/tex]
but I think this is silly.
Does anyone has an idea how to solve it?
I think that you're missing the fact that the number of moles ##n## increases with the pressure. The only two variables that change (in the equation of ideal gasses ##pV=nRT##) are ##p## and ##n##.
Quite so, but isn't there missing information? What is the initial pressure of the air being pumped in?
Thanks for your answers, haruspex you are right there are a lot of missing information, so actually i am looking for a general expression for the work and not a number.
I know that [tex]\frac{p_{i}}{p_{f}}=\frac{n_{i}}{n_{f}}[/tex] but that doesn't help me so much.
My next thought is, that dV is actually the volume from the air of the environment that is pumping in and not the volume of the gas in the bottle. But that doesn't work out.
Seems to me there are two parcels of air that change volume, that which was already inside and that which was added.
Likes Merlin3189
Actually, I went on with that , and at the end I got something that seems right to me . The derivation is though quite long so I am posting only the final equation.
[tex]W=[p(ln(\frac{p_{f}}{p_{0}}-1)+p_{0})]V[/tex]
pf indicates the pressure in the bottle after the compression, p0 the atmospheric pressure and V the volume of the bottle.
The pumping work is done external to the bottle by whatever is doing the pumping . This pumping may be more or less efficient depending in reality on a number of factors but usually the pumping process is considered for simplicity to be either an adiabatic or an isothermal process .
Given the pressure and temperature of air in the bottle at any time during the process of pressurisation the mass of air contained and the energy stored in the air are determinate and can be found by simple calculation .
I was thinking about the fact that you know the internal energy ##U## of the ideal gas before and after, so ##L=\Delta U##.
Yes you can work out the energy gained by the air . The pumping work though is something different .
So, how to find it?
Bestfrog said:
So, how to find it?
I'm unsure what interpretation @Nidum is suggesting, but here's one...
Since we don't know the original pressure of the added air, we can take each parcel of air to be injected to be already at the current pressure in the container. If a small number of moles, dn, is injected, there is a corresponding increase dP in pressure. You can write out the work done in that, and integrate.
I arrive to this$$\frac{dp}{p}=\frac{dn}{n}$$
So ##p=n\cdot e^C##, and finding the integration constant I have ##C=ln(RT/V)##, but I return to the initial ideal gasses equation
See if you can solve this simple problem :
A cylinder is closed at one end and fitted with a frictionless piston . The piston is initially located at the opposite end of the cylinder from the closed end .
What is the work done when the piston is forced part way down the cylinder so that the initially large volume of air in the cylinder is compressed to a smaller volume ?
Assume that the piston only moves relatively slowly and consider two different types of compression process : (a) adiabatic and (b) isothermal .
@Funky_Sp I'm just guessing, but would it be correct to say that you are currently learning about the open system (control volume) version of the first law of thermodynamics?
Part (b) The work done is ##W=nRT ln\frac{V_i}{V_f}##
Part (a) If i consider in my formula the change of volume (it seems to me that we know he final volume but not the final pressure), I have ##W=\frac{3}{2}nRT_i \cdot ((\frac{V_f}{V_i})^{-\gamma +1} - 1)## for a monoatomic ideal gas.
That's not what I get. Based on the open system (control volume) version of the first law, I obtain: $$W=V(P_f-P_i)$$
I was answering to the "problem" of Nidum in #13
Oh, I missed that. Sorry.
My answer is for the original problem as stated.
Related to Work done pumping air into a bottle
What is work done pumping air into a bottle?
Work done pumping air into a bottle is the amount of energy or force required to transfer air from the surrounding environment into a bottle.
What factors affect the work done pumping air into a bottle?
The factors that affect the work done pumping air into a bottle include the size and shape of the bottle, the initial and final pressure of the air in the bottle, the speed and efficiency of the pump, and any external forces such as gravity or wind.
How is work done pumping air into a bottle calculated?
The work done pumping air into a bottle can be calculated by multiplying the pressure difference between the initial and final states by the change in volume of the bottle.
Why is work done pumping air into a bottle important?
Work done pumping air into a bottle is important because it represents the amount of energy required to transfer air into the bottle, which can have implications for the efficiency and cost-effectiveness of pumping systems.
What are some real-world applications of work done pumping air into a bottle?
Work done pumping air into a bottle has many practical applications, such as inflating tires, filling air mattresses and balloons, and pressurizing containers for storage or transportation of gases.
