Work/Energy and Impulse/Momentum
  • Thread starter Bullwinckle
In summary, the conversation discusses the use of splitting derivatives in calculating line integrals and its validity. It also introduces the concept of parametrization and how it is essential in computing line integrals of vector fields. The conversation ends with the clarification that splitting derivatives is just a mnemonic device and mathematically it does not make sense.
Bullwinckle
If we take F=ma and multiply both sides by dt, we get
Fdt = ma dt
And then:
Fdt = mdv
And then:
Impulse = change in momentum.
OK; I get that.
I get a similar process for Work/Energy multiplying F=ma by ds on both sides as follows
Fds = ma ds
And using a ds = v dv to get
Fds = m v dv
Work = change in kinetic energy.
Now I have been coming to learn that it is not wise to split the derivative
For example the form: ads = vdv is possible in 1D.
And even then, it is fairly contorted: one should not, in a pure sense, split the derivative.
(I have gotten wind of issues like force is a one form and that explains the ds... can we avoid that advanced stuff for now?)
Is it possible get to the core of work/energy and impulse/momentum without splitting the derivative?
The sppliting of derivatives is useful trick for intuitively get the concepts around. However, I do not find it rigorous and I prefer just doing the integral.
For the Work/Kinectic energy relation:
The work is a line integral and it must be calculated via a parametrization of the curve (the trajectory). Our parametrization is simply [itex]\vec{r}(t)[/itex]. This vector line integral is calculated integrating over the domain of parameter [itex] t \in [t_0,t_1] [/itex] the function multiplied by the derivative/tangent vector (which happens to be the velocity).
[itex]Work = \int_{Path} \vec{F}·d\vec{r}=\int_{t_0}^{t_1} \vec{F} · \vec{v} dt = \int_{t_0}^{t_1} m\vec{a} · \vec{v} dt=\int_{t_0}^{t_1} m \frac{d\vec{v}}{dt} · \vec{v} dt = \int_{t_0}^{t_1} \frac{d}{dt}[\frac{1}{2} m \vec{v} · \vec{v}] dt = \int_{t_0}^{t_1} \frac{d}{dt}[\frac{1}{2} m v^2] dt = \frac{1}{2} m v^2(t_1) - \frac{1}{2} m v^2(t_0) = \Delta E [/itex]
And this is valid for arbitrarily close values of [itex] t_0,t_1[/itex].
For the impulse I cannot help you since I have a very simplistic view of the concept. Since it is the change over time of the momentum (i.e. the derivative)
[itex] \vec{I} = \frac{d\vec{p}}{dt} = m\frac{d\vec{v}}{dt} = m\vec{a} = \vec{F} [/itex]
(whenever tha mass is constant, which is pretty usual in classical mechanics)
OK, so are you not also stumbling over this:
dr = v dt (to progress from the second to third term)
Is that not taking this: dr/dt = v
And multiplying by dt?
Now I feel I am back at square-1
Or, are your words "parametrization" the key. Is this allowed in a parametrization?
Is there something about BEGINNING with dr = vdt on which I should focus?
The [itex] d\vec{r}[/itex] in the line integral is pure notation, a mere symbol. It does just means that the integral is a certain type integral: a line integral. Line integrals of scalar or vector functions/fields are mathematically completely different objects from typical integrals over subsets of [itex]\mathbb{R}^n [/itex] (they use a different measure).
https://en.wikipedia.org/wiki/Line_integral#Definition_2
I wouldn't matter if a chose a parametrization of the trajectory in which the particle travels the same path but at a different speed. As you can see, the definition(*) given by Wikipedia tells us that computing line integrals of vector fields requiere:
  • A parametrization (physicist usually use the typical [itex]\vec{r}(t)[/itex]).
  • The derivative of that parametrization function (with our choice, it'll be just [itex]\vec{v}(t) [/itex]). The splitting of derivatives gives you an intuitive mnemotecnic way of remembering this.
Then you just calculate the dot product of the [itex] \vec{F}[/itex] field and the tangent vector and integrate it over the parameter interval (in most of our cases will be the time interval). But we could have just used another parametrization of the same path (for example, instead of using time, we can use the arclength parameter).
This is mainly the theory that is behind the typical splitting of derivatives. It is valid to use but keep in mind it is just a way of remembering how to calculate line integrals. Mathematically, the splitting of derivatives makes no sense.
FAQ: Work/Energy and Impulse/Momentum
What is the difference between work and energy?
Work and energy are closely related concepts. Work is defined as the force applied to an object multiplied by the distance the object moves in the direction of the force. Energy, on the other hand, is the ability to do work. In other words, work is a measure of the transfer of energy from one object to another.
How is impulse related to momentum?
Impulse and momentum are both measures of an object's motion. Impulse is defined as the force applied to an object multiplied by the time over which the force is applied. Momentum is defined as the mass of an object multiplied by its velocity. These two concepts are related because a change in momentum is equal to the impulse applied to an object.
What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, it can only be transferred from one form to another. This means that the total amount of energy in a closed system remains constant. In other words, the total energy before an event must equal the total energy after the event.
How do we calculate work done by a force?
The work done by a force can be calculated by multiplying the magnitude of the force by the displacement of the object in the direction of the force. This can be represented by the equation W = Fd, where W is work, F is force, and d is displacement. The unit for work is joules (J).
What is the difference between elastic and inelastic collisions?
Elastic collisions are those in which the total kinetic energy of the system is conserved, meaning that no energy is lost during the collision. Inelastic collisions, on the other hand, are those in which some of the kinetic energy is lost, usually in the form of heat or sound. Inelastic collisions can also result in a change in the shape or structure of the objects involved.
