Work/Energy of Two Bungee Jumpers
  • Thread starter kcolman
  • Tags
    Bungee
In summary, the student's height will be greater than the height of the bridge over water if the initial energy from the bungee jumpers' spring force is greater than the work done by gravity with the weight cut in half.
kcolman
Exercise 1. Two bungee jumpers jump from a bridge. Jumper A is fastened to a bungee cord and holding on to jumper B. The cord has a stiffness k = 80 lb/ft. Find the unstretched length of the cord if the two students just reach the surface of the water at the maximum displacement. If student A let's go of student B at the surface of the water. Is there a problem for student A on the return? The distance between the bridge and water is 120 ft.
T1 + ƩU1-2 = T2
U1-2 = -WΔy Work of a weight
U1-2 = -ksΔs2 Work of a Spring Force
I solved the first part by using the principle of work and energy, setting T1 and T2 to zero and solving for the s-initial. However, I'm having trouble with the second part. I know that the potential energy from the first part gets transferred to the bungee jumpers kinetic energy in his ascension, and that his final height will be higher than if he didn't let go of the other bungee jumper. Also, I know his final kinetic energy will be zero at his maximum height, and I think the question wants to know if this height will be greater than the height of the bridge over water. Any thoughts?
welcome to pf!
hi kcolman! welcome to pf! :smile:
kcolman said:
… I know that the potential energy from the first part gets transferred to the bungee jumpers kinetic energy in his ascension, and that his final height will be higher than if he didn't let go of the other bungee jumper. Also, I know his final kinetic energy will be zero at his maximum height, and I think the question wants to know if this height will be greater than the height of the bridge over water.
that analysis looks correct …
so will it be greater? (if so, by roughly how much?) :wink:
Okay, I think I figured it out. I realized that the energy from the spring is equal to the total original gravitational energy, and set that equal to the work done by gravity with the weight cut in half. So my work looks like:
(1/2)kΔs = (W1+W2)y1
(1/2)kΔs = W1*y2
y2 = ((W1+W2)y1)/W1
y2 = (300 lb * 120 ft) / (150 lb)
y2 = 240 ft
So he doubles his initial height on his ascension... Probably hits his head pretty brutally. Does this look right?
hi kcolman! :smile:
yes, it will certainly rise well above the bridge
but it's not clear to me whether you've taken into account the downward force that the bungee rope will exert once he gets above the bridge
(and now I'm off to sleep :zzz: …)
I would approach this problem by first identifying the variables and forces at play. In this scenario, there are two bungee jumpers, jumper A and jumper B, who are connected by a bungee cord with a stiffness of k = 80 lb/ft. The distance between the bridge and water is 120 ft. The forces acting on the jumpers are gravity, the tension in the bungee cord, and air resistance.
To solve the first part of the problem, I would use the principle of work and energy, setting the initial kinetic energy to zero since the jumpers start from rest. The potential energy of the system at the beginning is equal to the potential energy at the end, when the jumpers reach the surface of the water. I would then use the equation U1-2 = -ksΔs2 (Work of a Spring Force) to solve for the unstretched length of the bungee cord.
For the second part of the problem, I would consider the energy transfer between the two jumpers when jumper A lets go of jumper B at the surface of the water. At this point, the potential energy of jumper B is transferred to kinetic energy, causing them to ascend higher than if they were still connected. However, since jumper A is no longer connected to the bungee cord, they would not experience the same amount of force and would not ascend as high as jumper B.
To determine if there is a problem for jumper A on the return, I would calculate their kinetic energy at the maximum height and compare it to the potential energy at the height of the bridge. If the kinetic energy is lower than the potential energy, then there may be a problem for jumper A as they may not have enough energy to reach the bridge again. However, if the kinetic energy is equal to or greater than the potential energy, then there should not be a problem for jumper A on the return.
In conclusion, as a scientist, I would approach this problem by considering the forces and energies involved and using equations to solve for the unstretched length of the bungee cord and to determine if there is a problem for jumper A on the return.
Related to Work/Energy of Two Bungee Jumpers
1. What is the work/energy relationship for two bungee jumpers?
The work/energy relationship for two bungee jumpers is based on the principles of conservation of energy. As both jumpers fall, their potential energy is converted into kinetic energy. When the bungee cord stretches, it absorbs some of the kinetic energy, causing the jumpers to slow down. As the jumpers reach the bottom of their fall, the stored energy in the bungee cord is released, propelling them back up.
2. How does the mass of the jumpers affect the work/energy of the bungee jump?
The mass of the jumpers does not directly affect the work/energy of the bungee jump. However, it does impact the speed and force at which they fall and are pulled back up. Heavier jumpers will experience a faster and more forceful fall compared to lighter jumpers due to their increased gravitational potential energy.
3. What role does gravity play in the work/energy of two bungee jumpers?
Gravity is a crucial factor in the work/energy of two bungee jumpers. It is the force that pulls the jumpers down and accelerates them towards the ground. Gravity also stores potential energy in the jumpers as they are lifted back up by the bungee cord. Without gravity, the work/energy relationship between the jumpers and the bungee cord would not be possible.
4. How is the length of the bungee cord related to the work/energy of two bungee jumpers?
The length of the bungee cord is directly related to the work/energy of two bungee jumpers. A longer bungee cord will stretch more and absorb more of the jumpers' kinetic energy, resulting in a slower and less forceful fall. On the other hand, a shorter bungee cord will stretch less, causing the jumpers to fall faster and experience a more forceful rebound.
5. What safety precautions should be taken into consideration for the work/energy of two bungee jumpers?
When conducting a bungee jump, there are several safety precautions that should be taken into consideration to ensure the work/energy of the jumpers is managed properly. The bungee cord and equipment should be regularly inspected and replaced if necessary. The jumpers should also be properly harnessed and secured to the bungee cord. Additionally, the jump location should be carefully chosen to ensure there are no obstacles or hazards that could cause harm to the jumpers.
