MHB Work energy principle and power
The discussion revolves around calculating the loss of gravitational potential energy (GPE) and the distance traveled by a child sliding down a playground slide. The child, with a mass of 40kg, experiences a loss of GPE of 800J when descending from a height of 2m. With a constant resistance of 112N, the distance traveled before coming to rest is calculated to be 7.14m. For the level part of the slide, the increase in GPE is corrected to -400J, leading to a distance of 4m traveled on the level section. The final distance on the level part is determined to be 3.14m after subtracting the distances.
Shah 72
MHB
A child of mass 40kg slides down a playground slide. The child starts from rest at the top of the slide, 2m above the ground. At the bottom of the slide it's slope levels off.
a) Find the child's loss of GPE
I got the ans 800J
there is a constant resistance of 112N throughout
b) find the distance the child has traveled when she comes to rest.
Using work energy principle
Increase in KE =0J
Increase in GPE= -800J
Work done against resistance = -112SJ
So I get S= 7.14m
The slide is inclined at an angle of 30 degree to the horizontal.
C) Find the distance the child travels on the level part of the slide.
I don't understand this part.
Increase in KE= 0J
Increase in GPE= 0- 40×10sin30×2= -400J
Work done by gravity= F×S
I don't understand how to solve further. Pls help
Mathematics news on Phys.org
I got the ans 800J
Increase in KE =0J
So I get S= 7.14m
Increase in KE= 0J
I think I did mistake while calculating Increase in GPE, it will be -800J
Work done by gravity = 200 SJ
So I get S= 4m
I subtract from full length 7.14-4= 3.14m
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
