Work, energy stored in solid sphere
In summary, the conversation discusses finding the energy stored in a uniformly charged sphere of charge q and radius R. The equations used are for electric field inside and outside the sphere, as well as for the work needed to assemble the charges from infinity. The final expression for the energy stored is simplified using the value of k, which is equal to 1/4piε0. The conversation also touches upon the physical intuition and mathematical process behind developing this equation.
mathnerd15
109
Find the energy stored in a uniformly charged sphere of charge q, radius R
[tex]Ein=\frac{qr}{4\pi\epsilon o R^3}, Eout=\frac{q}{4\pi\epsilon o r^2}... W=\int_{0}^ {R}\int_{0}^{2\pi}\int_{0}^{\pi}[\frac{qr}{4\pi\epsilon oR^3}] ^2sin\theta d\theta d\phi r^2\ dr+ \int_{R}^ {\infty }\int_{0}^{2\pi}\int_{0}^{\pi}[\frac{q}{4\pi\epsilon or^2}] ^2sin\theta d\theta d\phi r^2\ dr= 2\pi\epsilon o(\frac{q}{4\pi\epsilon o})^2(\frac{1}{5R}+\frac{1}{R})=\frac{q^2}{4\pi\epsilon o R}\frac{3}{5}[/tex]
by the way the work in this case is also like the effort needed to bring the whole solid sphere in from infinity by point charges or also the stored energy?
Is this a uniforms sphere of charge (i.e. as you may find in an insulator), or a spherical shell of charge (i.e. the charges are being placed on a conductor)? It affects the integral.
But yep - the electrostatic energy stored in a system of charges is the work needed to assemble them from infinity.
Nice LaTeX ... you can make a newline with a \\ to avoid running off the end of the page;
you can make subscripts with _{} like this: ##\epsilon_0## and ##E_{out}##.
trig functions are written \sin \cos etc.
thanks! this is a solid sphere of charge. I'm curious how you develop the mathematics for this, is it based on a physical intuition or a mathematical result of the electric field equation
OK... you seem to be using:
$$U=\int_V E^2d\tau + \int_S VEda$$
... it's a good idea to explain your process.
You ended up with: $$U=\frac{1}{2k}k^2q^2\left( \frac{1}{5R}+\frac{1}{R}\right)$$ ... where ##k=1/4\pi\epsilon_0##
Your next step is to simplify the expression.
Did you have any other questions?
I appreciate your attempt at finding the energy stored in a uniformly charged sphere. However, I would like to point out that your solution is not entirely correct. The correct equation for the energy stored in a uniformly charged sphere is given by W = (3/5)(k)(Q^2)/R, where k is the Coulomb constant and Q is the charge of the sphere. This equation can be derived using the formula for the potential energy of a point charge and integrating over the volume of the sphere.
To answer your question, the work in this case represents the effort needed to bring the whole solid sphere in from infinity by point charges. This also corresponds to the stored energy in the sphere, as energy is required to bring in the charges and overcome the repulsive forces between them.
FAQ: Work, energy stored in solid sphere
1. What is work?
Work is defined as the force applied to an object multiplied by the distance the object moves in the direction of the force. It is a measure of the energy transferred to or from an object.
2. How is work related to energy stored in a solid sphere?
When a force is applied to a solid sphere, work is done on the object which results in an increase in its kinetic energy. This energy is stored in the form of potential energy in the object's molecules, creating a temporary deformation in the sphere.
3. How is energy stored in a solid sphere calculated?
The potential energy stored in a solid sphere can be calculated using the formula PE = 1/2 kx², where k is the spring constant and x is the distance the object is deformed.
4. What factors affect the energy stored in a solid sphere?
The energy stored in a solid sphere is affected by the material properties of the sphere, such as its elasticity and density, as well as the amount of force applied to deform the object and the distance it is deformed.
5. Can energy stored in a solid sphere be converted into other forms of energy?
Yes, energy stored in a solid sphere can be converted into other forms of energy such as heat or sound when the object returns to its original shape. This is known as elastic potential energy and is often used in devices such as springs and rubber bands.
