Work-energy theorem and Tension Force
In summary: At the top, his KE is zero and his PE is at a maximum.In summary, Tarzan swings on a 9.0m long vine at a speed of 5.0m/s. The tension force in the vine does no work on him since it is acting at a 90 degree angle to his motion. However, due to the work-energy theorem, his initial kinetic energy is converted to gravitational potential energy, allowing him to reach a maximum vertical height before swinging back down.
RedDanger
While running at a speed of 5.0m/s Tarzan grabs a 9.0m long vine hanging vertically from a tall tree in the jungle and swings on it. As he swings on the vine, how much work is done on him by the tension force in the vine? To what maximum vertical height can he swing if he masses 95Kg?
KEi + PEi = KEf + PEf
Work = F*deltaX*cos(angle)
Well, because the tension force is acting at 90 degrees from the direction of motion, doesn't it do 0J of work on Tarzan because cos(90) = 0?
On the second part, when I apply the work-energy theorem, I end up with (0.5Vi2 - 0.5Vf2)/g = height final, which would go to zero because Tarzan is an object in motion and is not being acted on by any force except gravity and the tension force, which if the vine does not break then it cancels out the Fg on Tarzan. Therefore, Tarzan's final velocity = initial velocity and height final = 0.
Is this correct?
Good!
Good. That follows from conservation of energy.
No. The tension force does not cancel out Fg. (Is your answer reasonable, based on your experience?) While the tension does no work on Tarzan, gravity does. Thanks to the swinging vine, his initial KE is converted to gravitational PE.
FAQ: Work-energy theorem and Tension Force
What is the work-energy theorem?
The work-energy theorem states that the work done on an object is equal to the change in its kinetic energy. This means that the work done by all the forces acting on an object will result in a change in its kinetic energy, either increasing or decreasing it.
How is the work-energy theorem related to tension force?
The work done by a tension force is a component of the total work done on an object. This means that the tension force contributes to the change in kinetic energy of an object, as described by the work-energy theorem.
Can the work-energy theorem be applied to both linear and rotational motion?
Yes, the work-energy theorem can be applied to both linear and rotational motion. In linear motion, the change in kinetic energy is equal to the net work done by forces acting on the object. In rotational motion, the change in kinetic energy is equal to the net torque applied on the object.
How is tension force calculated?
Tension force is a type of contact force that is exerted between two objects in contact with each other. It is calculated using the equation T = mg + ma, where T is the tension force, m is the mass of the object, g is the acceleration due to gravity, and a is the acceleration of the object.
Can tension force be negative?
Yes, tension force can be negative. This occurs when the direction of the tension force is opposite to the direction of motion of the object. In this case, the tension force is acting to slow down the object, resulting in a negative change in kinetic energy.
