Work=Force*Stretch: Why is this?
  • Thread starter Thread starter johann1301
The equation Work = Force * Stretch (or displacement) is fundamental because it reflects the direct relationship between force applied and the distance moved in that direction. This simplicity arises from the definition of work as a measure of energy transfer in a system, which does not allow for more complex relationships involving powers or fractions. While forces can vary during stretching, the basic principle holds true when force remains constant. The equation's straightforward nature aids in understanding and calculating work efficiently. Ultimately, this simplicity is beneficial for practical applications in physics.
johann1301
216
I am- and have always been a bit puzzled as to why Work=Force*Stretch. I guess it makes sense that both stretch and force is involved, but why such a simple equation? Why Isn't it for example;
W=0,25F*S^2
or..
W=(F^S)/2
or some other equation?
How did we figure out that Work=Force*Stretch?
i believe you want to know why work is force*displacement(stretch as you called it), right?...
Here's the deal, you cannot have another equation of work with powers greater than one or less than it for force or the displacement...why?...because work isn't something that you see in nature, as it is with distance,
Work is a concept invented by physicists to understand whether a system is efficient enough...it has been defined that way, F*S, no other way is possible...the equations you mentioned ...they could mean something ...but certainly not work...just like you being happy means having a smile and stuff ...Why isn't being happy associated with having a frown...same logic here...cause it is defined as having a smile...
W=0,25F*S^2
or..
W=(F^S)/2
Actually, it very often isn't as simple as force times stretch because the force tends to change as you stretch things. It is, however, force times distance moved (in the direction of the force) as long as the force doesn't change.
Why is it such a simple formula? Well, consider a (zero weight) lever and assume there is no friction. The work you do in moving the long bit must be equal to the work done on the heavy weight on the short bit. If there is no extra energy put in or lost then this must be true. It always turns out that the force times the distance moved is the same value whatever the lengths on each side of the lever. This quantity that is always equal to force times distance is the work done.
Also, consider the energy involved in lifting a block. Lifting it twice as far would, reasonably, take twice as much energy. Lifting two blocks would also take twice as much energy.
Need I go on? Don't look a gift horse in the mouth. You would really be moaning if it were a more difficult formula to remember. :wink:
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
