In summary, the question involves an explorer spacecraft descending towards Mars using a rocket engine for braking. The spacecraft's initial position has a potential energy of -2.8x10^10 J and a kinetic energy of 3.0x10^9 J, while some time later it has a potential energy of -3.4x10^10 J and a kinetic energy of 1.0x10^9 J. The work done by the rocket engine in braking the spacecraft is calculated by subtracting the change in potential energy from the change in kinetic energy, giving a result of -8.0x10^9 J. The negative potential energy indicates that the spacecraft is getting closer to Mars, and the braking negates the
ashyyamora
Does not use the template because it was originally posted in a non-homework forum
Hi guys. I'm new to this forum so I'm not sure if I'm posting this in the right place or correctly, but I was totally stumped on a Physics 12 question as I was studying for my exam.
The question is:
An explorer spacecraft is descending towards Mars using a rocket engine for braking. The spacecraft has Ep = -2.8x10^10 J and Ek = 3.0x10^9 J at its initial position. Some time later the spacecraft has Ep = -3.4x10^10 J and Ek =1.0x10^9 J. How much work did the rocket engine do in braking the spacecraft ?
At first, I thought it was work done = change in kinetic energy, but that's not the answer. Then I realized that the change in kinetic energy and the change in potential energy were not the same, and that's where I was completely lost. What does it mean when its gravitational potential energy increases in the negative? Is it moving closer or farther from the planet? And how would I go about solving this question?
I tried (although I don't know why): Wbrakes - [(-3.4x10^10) - (-2.8x10^10)] = -2.0x10^9; Wbrakes = -2.0x10^9 - 6.0x10^9 = -8.0x10^9 J which is the correct answer. I just don't know if that's the correct solution and if it is, why.
Without any breaking, the rocket's total energy (sum of potential +kinetic) would remain the same. With braking applied, as the rocket approaches the planet and its kinetic energy becomes more negative, normally the change is all converted to kinetic energy to keep the total energy constant. Braking keeps this from occurring, and with sufficient braking, you could even get the rocket to land on the planet rather than crashing into it at high speed.
If the potential energy's magnitude is increasing, does it mean the spacecraft is getting closer or farther from Mars? Why does the braking affect the potential energy?
A more negative potential energy (larger in magnitude) means it is getting closer to the planet. Potential energy changes with distance ## r ## from the center of the planet) by the formula ## E_p=U=-GMm/r ## where ## G ## is the gravitational constant ## M ## is the mass of the planet and ## m ## is the mass of the spacecraft . You can see as ## r ## gets smaller that ## U ## becomes more negative (larger in magnitude). ## \\ ## Editing... Meanwhile the braking (retro-rocket) affects the kinetic energy and thereby the total energy. The braking does not affect the potential energy=that is simply a function of the location (## r ##). Again, without braking the total energy stays the same so that if the potential energy becomes large and negative, that means without braking that the kinetic energy will become large and positive. The braking lowers the energy and lowers the total energy as well as the kinetic energy. Of course if you fired the same (retro-)rocket in the other direction, you could actually increase the total energy and increase the kinetic energy tremendously.
Okay I think I get it. To recap simply: the approaching of the spacecraft to the planet is increasing the magnitude of the potential energy, but it's negatively, meaning that the kinetic energy is increasing positively. So the braking is not only negating that gain in kinetic energy, but it's also making it lose an additional 2.0x10^9J of kinetic energy. So in total, the braking is negating 2.0x10^9J + the 8.0x10^9J of kinetic energy gained from approaching the planet (gained due to acceleration from gravity).
Does that sound right?
Thanks for your help!
The 8.0 you mentioned should be a 6.0 ,## (3.4-2.8) \cdot 10^{10}=6.0 \,\cdot 10^9 ##, so that ## 2.0 \,\cdot 10^9 J+6.0 \cdot \,10^9 J=8.0 \cdot \, 10^9 J ##.
Oh yeah that's right. My bad. Thanks!
Likes Charles Link
Related to Work, Gravitational Potential and Kinetic Energy, Spacecraft
1. What is work in relation to spacecraft?
Work is defined as the force applied to an object multiplied by the distance the object moves in the direction of the force. In terms of spacecraft, work is the force exerted by the spacecraft's engines to move the spacecraft through space.
2. How does gravitational potential energy affect spacecraft?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. In the case of spacecraft, this energy is important for orbital mechanics. It determines the altitude, speed, and trajectory of a spacecraft in orbit around a planet or other celestial body.
3. What is kinetic energy and how is it relevant to spacecraft?
Kinetic energy is the energy an object possesses due to its motion. In terms of spacecraft, it is important because it allows the spacecraft to overcome the force of gravity and maintain its orbit or accelerate to a higher orbit. Kinetic energy is also important for spacecraft re-entry and landing.
4. How do scientists calculate the potential and kinetic energy of a spacecraft?
The potential energy of a spacecraft is calculated by multiplying its mass by the acceleration due to gravity and the height of its orbit. The kinetic energy is calculated by multiplying half of the spacecraft's mass by its velocity squared. These values can be used to determine the total energy of the spacecraft and its trajectory.
5. What factors affect the work, potential energy, and kinetic energy of a spacecraft?
The work, potential energy, and kinetic energy of a spacecraft are affected by its mass, position, and velocity. Changes in any of these factors, such as a change in engine thrust or a gravitational slingshot maneuver, can alter the energy of the spacecraft and its trajectory through space.
