Work, Gravity and air resistance question
In summary, statement II is true as neither gravity nor air resistance do any work during the flight of the mass. Statement I is false as gravity does work against the resistance from inertia and air resistance during the flight. The net work done on the object is zero.
UncleJames119
A mass m is fired straight up from a cannon, through the air, it rises to a maximum height, and then it falls back down to its initial height. There is air resistance. Consider these three statement.
I. The work done by the force of gravity during the flight is Zero.
II. The work done by the force of friction during the flight is zero.
How many of these statements are true?
A.) All are true./
B.) None are true.
C.) Only statement I is true
D) Only statement II is true.
when a mass is brought to rest, the work done by the frictional force on it is equal to the kinetic energy of the object, KE=1/2 mv2. (friction) Newton’s universal law of gravitation:
F = Gm1m2/r2,
where F is the force due to gravity, between two masses (m1 and m2), which are a distance r apart; G is the gravitational constant.
At first I thought statement C was true, but because When an object is falling freely, the force of gravity is doing work against the resistance from inertia and the air resistance or drag on the object. So I am thinking both statements are false because gravity is doing work against the resistance from inertia and the air resistance or drag on the object. The forces acting on the object are gravity and the opposite or resistive forces of inertia and air resistance.
Because the question is saying that both gravity and air friction arent doing any work when the object falls
i think none are true
and isn't air resistance kinetic energy? Thanks for your help! :)
Work done is always force into displacement. As the object comes back to it's initial position, there is 0 net work on the body. So, I guess there is no work done by either force on the body. I may be wrong though, I'm not sure.
Thanks for your input. I've came to the same conclusion to, but I'm confused about the "flight" part of the question.
The gravitational force first opposes the motion of the body(while the body is moving upwards) and then supports the motion while the body falls from the max height.So what will be the workdone by gravity in the whole trip?
Welcome to PF!
Let the maximum height be h
work done by gravity during upward flight = -mgh (-as force is opposite to displacement, cos180 = -1)
work done by gravity during downward flight = mgh
Net force = -mgh+mgh = 0
I don't know the exact expression for air resistance, but since it always acts against the direction of motion, it'll act downward during upward flight, and upward during the downward flight. My mind says it'll be zero.
yes it is correct for gravity.But air resistance opposes the motion of the mass irrespective of its direction.Hence it always does negative work which is not zero
So then the answer would be none are true since both gravity and air resistance are putting in work, right?
No see the post #4.Gravity does a negative work when the mass is going up and positive work when the mass is descending.So the net work will be zero.Are you getting it?
Likes 1 person
So gravity itself cancels out, and that only leaves friction. So then I guess my answer would be C right?
right:)
Likes 1 person
I really want to thank you for helping me. You guys are so awesome. My major is Computer Science but my minor is physics. I'm starting at the bottom, but again thank you all for tolerating me! Michio kaku and Einstein came to me in a dream, and I hope the next post I make, will be the image of my BS degree! You guys are so awesome and thanks!
you are always welcome:))
FAQ: Work, Gravity and air resistance question
What is work?
Work is defined as the application of a force over a distance. In scientific terms, this can be calculated as the product of force and distance, or in other words, the amount of energy required to move an object.
How does gravity affect work?
Gravity is a fundamental force that pulls objects towards each other. When an object is lifted against the force of gravity, work is being done to overcome this force. The amount of work done is directly proportional to the mass of the object and the distance it is lifted.
What is air resistance?
Air resistance, also known as drag, is the force that acts against the motion of an object through a fluid, such as air. This force is caused by the collisions of air molecules with the surface of the object, and it increases as the speed of the object increases.
How does air resistance affect work?
Air resistance can affect work in two ways. First, it can increase the amount of work needed to move an object through the air due to the additional force acting against it. Second, it can decrease the work done by a falling object, as it converts some of the potential energy into heat and sound through air resistance.
How can air resistance be reduced?
Air resistance can be reduced by changing the shape and surface texture of an object. Smoother, streamlined surfaces experience less air resistance compared to rough, irregular surfaces. Additionally, decreasing the speed of an object can also reduce the effects of air resistance.
