Work, heat, thermodynamics Cylindric Piston
In summary: This is a common problem in many textbooks.In summary, the question involves a gas in a cylinder with a movable piston and changing external pressure. The work done is calculated using the equation w=-pdeltaV, but the type of compression must be known for the correct answer. The textbook provides incomplete information, making it difficult to accurately solve the problem.
alingy1
325
Consider 5.5 L of a gas at a pressure of 3.0 atm in a cylinder with a movable piston. The external pressure is changed so that the volume changes to 10.5 L.
a) Calculate the work done, and indicate the correct sign.
b) Use the preceding data but consider the process to occur in two steps. At the end of the first step, the volume is 7.0 L. The second step results in a final volume of 10.5 L. Calculate the work done, and indicate the correct sign
c) Calculate the work done if after the first step the volume is 8.0 L and the second step leads to a volume of 10.5 L.
a)w=-7.86J
b)w=-9J
c)w=-9.085J
Could you please check my answers? I have a test on thermodynamics soon.
Basically, I used w=-pdeltaV.
For example,
a)p=5.5L*3.0atm/10.5L
deltaV=10.5L-5.5L
w=-pdeltaV=-7.86J.
However, I am not sure for b) and c). The textbook seems to convey that I should get different answers for b) and c). But, they are very similar!
That equation is only valid for constant P, which is clearly not the case here.
Then how do i solve it?
You have to use
w = - \int_{V_i}^{V_f} P \; \mathrm{d} V
where ##P## will be a function of ##V##. For an ideal gas, you substitute ##P## using the ideal gas law (if the temperature is constant and can be taken out of the integral).
I notice that no details are given about the kind of compression being done (isothermal, adiabatic, ...). If it's adiabatic compression, you have to use the first law to get ##\Delta U## from which you can deduce ##W##.
Also, I don't understand why doing the compression in steps can change the total work done.
Likes 1 person
This question comes from Chemistry, Zumdahl, edition 9 in the chapter 6, problem 6/7.(for those who may have the book)
We never saw the types of compression and cal II is not prereq for my chemistry course.
Here is an example of a similar problem we did in class:
Find work done by gas in cylindrical piston:
Vi=0.015L
Vf=0.025L
Pexternal=1atm
W=-1atm*(0.025L-0.015L)
Does this make sense?
I don't have that book. If it's not too much work to post the full problem, it would help figure out what is asked, as there seems to be information missing.
Vi=0.015L
Vf=0.025L
Pexternal=1atm
Yes. You see, here the external pressure is constant, therefore you can treat it as a constant (!) and look only at the change in volume.
This is the whole question! It seems quite disappointing to be honest with you. It is definitely not clear.
I have this book -- though mine is 6th ed., but it has the same problem. I confirm that the problem statement was posted completely and accurately as given in the book. And I agree that we need information about the type of path taken to solve the problem. Isothermal? A sudden drop to the final pressure, followed by expansion to the final volume? Something else? We simply don't know.
I will note that the question comes from a section called "In-Class Discussion Questions", which according to the book "are designed to be considered by groups of students in class." This is in contrast to questions and exercises that would typically be given as homework.
Since integral calculus is not required for the class, I presume the work is intended to be calculated using simple geometric area formulas to get "the area under the curve" in a P-V diagram. But, no information is given on what shape to use for the curve.
your answers are wrong for a and b. those units should be L x atm, if you wanted the answers in joules then you would need to multiply your answers by 101.3
The answer to this problem depends on the original intent of the person who made it up. If the intent was for the external pressure to be changed gradually (reversibly), then the approach recommended by @DrClaude is appropriate. If the intent was for the external pressure to be dropped suddenly to a lower value and to then allow the gas to re-equilibrate at this new pressure, then the approach being used by @alingy1 is appropriate. Since subsequent parts of the problem involve two steps, it seems to me that the latter was the original intent. But, who really knows what the person who made it up was thinking.
Related to Work, heat, thermodynamics Cylindric Piston
1. What is work in relation to thermodynamics?
Work in thermodynamics refers to the transfer of energy from one system to another through the application of a force. This can be in the form of mechanical work, electrical work, or other forms of work.
2. How is heat involved in thermodynamics?
Heat is a form of energy that is transferred from one system to another due to a temperature difference. In thermodynamics, heat is often used to describe the transfer of thermal energy between systems, and it plays a crucial role in understanding the behavior of gases and other substances.
3. What is a cylinder piston in thermodynamics?
A cylinder piston is a device used in thermodynamics to change the volume of a gas by pushing or pulling on a piston within a cylinder. This allows for the compression or expansion of the gas, which can then be used to do work or transfer heat.
4. How does a cylinder piston work?
A cylinder piston works by converting the energy from the movement of a piston into work or heat. As the piston moves, it compresses or expands the gas within the cylinder, which can then be used to do work or transfer heat to another system.
5. What is the relationship between work and heat in thermodynamics?
In thermodynamics, work and heat are two forms of energy transfer between systems. Work is the transfer of energy due to the application of a force, while heat is the transfer of thermal energy due to a temperature difference. The first law of thermodynamics states that the total energy of a closed system remains constant, meaning that any work done on the system must be accompanied by a change in heat, and vice versa.
  • Thermodynamics
