Work in a process which is both adiabatic and isobaric?
In summary: W=\int{p_{surr}dV}$$, where ##p_{surr}## is the force per unit area exerted by the surroundings on the gas at the moving interface. For a reversible process, the pressure of the gas is uniform and matches the pressure of the surroundings. But for an irreversible process, the gas pressure is non-uniform and, moreover, viscous stresses contribute to the force that the gas exerts on the surroundings (and vice versa). So, for the case where the gas is initially at equilibrium at a pressure ##p_1##, and the surrounding pressure at the interface is suddenly dropped to a lower value ##p
Soren4
128
In a adiabatic process (not necessarily reversible) from ##V_a## to ##V_b## the work can be written as $$W=\frac{p_aV_a-p_bV_b}{\gamma-1}$$ Where ##\gamma= \frac{c_p}{c_v}##
Suppose that the adiabatic process in question (again, not necessarily reversible, so ##pV^{\gamma}## can also not be constant) is also isobaric: then ##p_a=p_b=p## so
$$W=\frac{p(V_a-V_b)}{\gamma-1}\tag{1}$$
On the other hand in any adiabatic process $$W= p(V_b-V_a)\tag{2}$$
The expressions ##(1)## and ##(2)## are different, so which of the two is to be consider the right one in this case?
We get the first equaltion this way
$$W=\int_{(a)}^{(b)}pdV=p_aV_a^ \gamma\int_{V_a}^{V_b} \frac{dV}{V^ \gamma}=p_aV_a^ \gamma\left ( \frac{V^{1- \gamma}}{1- \gamma} \right )|_a^b =\frac{p_aV_a^ \gamma\left (V_a^{1- \gamma} - V_b^{1- \gamma}\right )}{\gamma -1}=\frac{p_aV_a - p_bV_b}{\gamma -1}$$
As you see, the requirement
$$p_aV_a^ \gamma=p_bV_b^ \gamma=pV^ \gamma = const$$
is necessary.
Likes Soren4
EDIT: I am stupido:)
As Irene Kaminkowa pointed out, the formula is correct.
First off:
Soren4 said:
Suppose that the adiabatic process in question (again, not necessarily reversible, so ## pV^{\gamma} ## can also not be constant
Isn't an adiabatic process DEFINED by not having any heat flow? Then it is reversible and isentropic per definition.right ?
And you can directly derive this ## pV^{\gamma}= constant ## from the requirement of no heat flow.
You can compare it to this http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/adiab.html
PS: If the pressure is the same in the initial and final state there can not be any work done...
Since if ##p ## doesn't change ## V ##also doesn't change due to ## pV^{\gamma}= constant ##
Tazerfish
formula (1) is right. See the transformations above.
Soren4
Conclusion: if you want a process to be not only adiabatic but also isobaric, then all your system parameters - (p,V,T) - will remain constant.
To prevent speculations about γ, it's also constant, or - again, speaking formally - we cannot get formula 1.
Likes Soren4
This is incorrect for an adiabatic irreversible process.
For any expansion or compression process, the work done by the system on the surroundings is always given by $$W=\int{p_{surr}dV}$$, where ##p_{surr}## is the force per unit area exerted by the surroundings on the gas at the moving interface. For a reversible process, the pressure of the gas is uniform and matches the pressure of the surroundings. But for an irreversible process, the gas pressure is non-uniform and, moreover, viscous stresses contribute to the force that the gas exerts on the surroundings (and vice versa). So, for the case where the gas is initially at equilibrium at a pressure ##p_1##, and the surrounding pressure at the interface is suddenly dropped to a lower value ##p_2## and held at that value until the gas reaches a new equilibrium (at a new volume), the work done by the system on the surroundings in this irreversible expansion is just $$W=p_2(V_2-V_1)$$
Note that ##p_1## is not even present in this equation, except to the extent that it relates to ##V_1##.
For more on how to determine the work done in reversible and irreversible expansions, see my Physics Forums Insights article: https://www.physicsforums.com/insights/understanding-entropy-2nd-law-thermodynamics/
As I said above, for the case where the expansion is irreversible at a constant lower pressure, the work is ##W=p_2(V_2-V_1)##. Thus, Eqn. 2 is correct and Eqn. 1 is incorrect for this irreversible adiabatic expansion.
If you would like to carry out a full analysis of the adiabatic irreversible isobaric expansion case, I will be glad to help you. Unlike what you have been told so far, it will certainly give a different result than the adiabatic reversible isobaric expansion case.
Likes Soren4 and beamie564
Aniruddha@94 said:
The volume and temperature can still change, right?
Wrong. For the processes I consider.
Simple logic
$$pV^\gamma = const~ AND ~p=const~AND~ \gamma = const\rightarrow V = const$$
Simple logic
How did I miss that! Sorry. So it means processes which are adiabatic and isobaric ( and reversible) aren't possible?? ( since no state function changes)
Our equations bind macro-parameters, while we try to describe micro-world.
What is more, we use the model of "ideal gas". Here, one may feel free to grunt that our world is far from "ideal".
How can we implement the "adiabatic and isobaric" processes in practice? To create adiabatic conditions we are to isolate our reservoir, so, the external temperature impact is forbidden. Isobaric conditions demand to fix the pressure. Then, all macro-parameters in our "ideal" system must be stuck.
Since life goes on, the particles continue their chaotic movements, so p,V,T can experience fluctuations, even within the given model. But these fluctuations are negligible.
By the way, Chestermiller,
I wonder, how we can obtain "1) adiabatic, 2) isobaric, and 3) irreversible" process experimentally?
Yes.
As I said, if the process is irreversible, the micro parameters vary spatially throughout the system (temperature and pressure), so the ideal gas law (or other equation of state) does not apply macroscopically to the gas. In addition there are viscous stresses present during an irreversible expansion or compression such that, even at the piston face, the force per unit area is not determined by the local version of the ideal gas law ##p=\rho RT## (where ##\rho## is the local molar gas density and T is the local temperature). There are additional (viscous) contributions to the force per unit area related not just to how much the volume has changed but also how fast the volume is changing.
What we mean when we use the term irreversible isobaric process is that we suddenly change the force per unit area at the piston face at time zero and hold it at that value during the entire expansion or compression. So, in terms of pure semantics, it is true that the constant pressure during the process is not equal to that which was present immediately before the initial change. But, be that as it may, this is what we mean by an irreversible isobaric process.
We have complete control over the force that we apply at the piston at any time. All we need to do is move the piston as fast or as slow as we desire while measuring the force per unit area acting on the piston face (say, by using a flush mounted pressure transducer) and adjusting the piston speed as necessary to hold the force constant. It turns out that the work done by the gas this way can be shown to be the same as that obtained if we suddenly removed or added a weight from the top of the piston and allowed the system to re-equilibrate. In this latter case, force of the piston is not constant throughout the expansion, but, in the end, the total amount of work will be exactly the same.
Likes Irene Kaminkowa
Thus, to illustrate irreversibility we have to carry out two experiments.
In both of them we isolate our reservoir so that δQ = 0 (adiabatic conditions).
Assume the reservoir is a cylinder.
1) reversible process.
- measure the pressure pA when the piston is at the initial Level A;
- move the piston up to Level B smooth and slow. Measure the pressure pB;
- move the piston down, also quite smooth and slow, back to Level A. Measure the pressure pF (final).
CLAIM: pA = pF (the same volume and the same pressure, since during the whole experiment ##pV^ \gamma = const##)
2) irreversible process.
- move the piston up to Level B sharp and fast. Measure the pressure pB;
- move the piston down, back to Level A (as you like - either slow or fast). Measure the pressure pF.
CLAIM: pA ≠ pF (the same volume but the pressures differ, since ##pV^ \gamma \neq const##). We are not back.
Good subject for a lab )
Correct.
This is not the process I was describing, but it certainly would be irreversible. The final pressure ##p_F## would be higher than ##p_A## because the final temperature would be higher. This would be the result of viscous dissipation of mechanical energy to internal energy during the process.
Chestermiller said:
Yes.
What? Now I'm confused again. Don't reversible adiabatic processes follow the curve ##PV^\gamma=const##. Then if we impose the restriction that ##P## is constant, ##V## also doesn't change (and neither does ##T##).
Simple logic
That means such a process (adiabatic and isobaric) cannot occur. Correct?
ps. I'm talking only about ideal gases and reversible changes.
I was about to post the same question, and to my surprize I saw that the same questions is already on the top of the discussion list. Really surprizing. :-O
Actually I know an answer to this question, and my answer is different from what most of the teachers teach.
I want opinion of members here about my working.
My working is as follows.
Lets start by describing the scenario first.
lets say there is some gas in the chamber which has a frictionless piston whose mass is 10kg. The system is in equilibrium ie the pressure inside the chamber matches with the constant pressure outside P0. let's forget gravity for time being for the sake of simplicity (or just consider that the motion of piston is horizontal). Now let's say the piston is compressed so that volume of chamber is reduced to half. The piston is then released. The walls of the chamber and the piston is made of insulating material. Will the process be reversible or irreversible.
According to me (if we are considering frictionless system), the process will be reversible and will be oscillatory.
Following are the equations which were used to derive that the motion is oscillatory
PV = nRT
dQ=0
(P-P0)A = ma (where a is acceleration of piston)
V=V0 + xA (where x is displacement of piston)
1) Go from thermodynamics to statictics.
2) Consider entropy as the measure of order vs chaos.
3) Add quantum effects.
4) Forget about insulation, consider open systems as they are.
5) Come back to thermodynamics, use experiments, computer simulations to check your theories
6) Go to any steps from 1 to 5 when necessary
We all end at step 2, so do not forget to add a bit of order in your own system )
Related to Work in a process which is both adiabatic and isobaric?
1. What is an adiabatic process?
An adiabatic process is one in which there is no exchange of heat with the surroundings. This means that the system is thermally insulated and there is no transfer of heat energy in or out of the system.
2. What is an isobaric process?
An isobaric process is one in which the pressure of the system remains constant. This means that the system is able to exchange heat energy with the surroundings, but the pressure remains the same throughout the process.
3. How does a process being both adiabatic and isobaric affect the system?
In a system that is both adiabatic and isobaric, there will be no exchange of heat with the surroundings and the pressure will remain constant. This means that the system will experience a change in temperature, but the pressure will remain the same.
4. What are some examples of adiabatic and isobaric processes?
Some examples of adiabatic and isobaric processes include the expansion or compression of a gas in a piston-cylinder system with a constant external pressure, and the flow of a gas through a tube with a constant cross-sectional area and external pressure.
5. What are the applications of adiabatic and isobaric processes?
Adiabatic and isobaric processes are commonly used in thermodynamics and engineering applications, such as in the design of heat engines and refrigeration systems. They are also important in the study of atmospheric and oceanic processes, as well as in chemical reactions and industrial processes.
  • Mechanics
22K
