athul jyothis
Pls give me an eq relating work needed to rotate armature of generated
athul jyothis said:I would like to know what will be the strength of permanent magnet used in a household generator
The work needed to rotate the armature of a generator refers to the amount of energy required to turn the armature and produce electricity.
The work needed to rotate the armature of a generator is calculated by multiplying the torque required to turn the armature by the angle through which it is turned.
The work needed to rotate the armature of a generator is affected by the size and weight of the armature, the amount of resistance in the circuit, and the speed at which the armature is rotating.
The work needed to rotate the armature of a generator is important because it determines the amount of electricity that can be produced by the generator. If the work needed is too high, the generator may not be efficient enough to produce a sufficient amount of electricity.
The work needed to rotate the armature of a generator can be reduced by using a more efficient design, reducing the weight and resistance of the armature, and increasing the speed of rotation. Regular maintenance and lubrication can also help reduce the work needed to rotate the armature.
