- #36
- 27,982
- 19,480
Given the state of this thread, please open a new thread. You still have to solve this one, as no one has posted a solution.Differentiate it said:Could I please get help with this one too?
I see @PeroK has beaten me to it, but since I've already written it ...erobz said:To me it seems like to be consistent we always should be writing the following:
$$ W = \int F ~dx = \int \left( m \frac{dv}{dt} + v \frac{dm}{dt} \right) dx $$
Then we can see that for the chain at constant velocity ##v## problem:
$$ W = \int F ~dx = \int \left( \cancel{ m \frac{dv}{dt}} + v \frac{dm}{dt} \right) dx $$
$$ \implies \int F ~dx = \int v \frac{dm}{dt} dx = \int v \frac{dm}{dx} \frac{dx}{dt} dx = \int v \frac{dm}{dx} v dx = v^2 \int_{0}^{l} \lambda ~dx = \lambda l v^2 $$
However, that doesn't really play nicely either. That factor of ##\frac{1}{2}## out front is missing, or should it not actually be there?
So the bastardisation of Newton's second law was the root of the problem after all:Steve4Physics said:Your analysis seems to ignore the process of acceleration and assumes each slice is instantaneously accelerated from 0 to ##v##; as a consequence, it will give the work done accelerating each slice as ##\frac {Fv^2}a## which is twice the correct value.
Just refer to diagram shown in post #17 above.Differentiate it said:Could I please get help with this one too?
Just to add that if ##x## is the position of the end of the rope, then the average velocity of the mass element ##dm## during its acceleration is ##\frac 1 2 (\frac {dx}{dt})##.PeroK said:So the bastardisation of Newton's second law was the root of the problem after all:
$$Fdt = vdm \Rightarrow KE = Fdx = Fdt\frac{dx}{dt} = v^2dm$$
So it seems. One of my Physics Profs. declared to us that Newtons 2nd Law was actually:PeroK said:So the bastardisation of Newton's second law was the root of the problem after all:
If ##m## is taken to be constant, then it's a minor restatement of the law in terms of momentum.erobz said:So it seems. One of my Physics Profs. declared to us that Newtons 2nd Law was actually:
$$\sum \vec F = \frac{d}{dt} \Big( m \vec v \Big)$$
What was the point of that...
Could we then consider only the location of the CoM for each phase of the lifting?Steve4Physics said:Just to add that if ##x## is the position of the end of the rope, then the average velocity of the mass element ##dm## during its acceleration is ##\frac 1 2 (\frac {dx}{dt})##.
Then$$Fdt = vdm \Rightarrow KE = Fdx = Fdt\frac{dx}{dt} = v^2dm$$becomes$$Fdt = vdm \Rightarrow KE = Fdx = Fdt {\frac 12}(\frac {dx}{dt}) = \frac 12 v^2dm$$ and things look sensible.
Not sure I fully understand.Lnewqban said:Could we then consider only the location of the CoM for each phase of the lifting?
That location, and the acceleration and velocity of each CoM (of the lifted mass only at each instant) will always be half the value of the vertically moving end of the rope.
Sure, but to make that work you have to assume perfect elasticity and take the rope to have been originally in a vertical stack of zero height, i.e. a spring of zero relaxed length.PeroK said:The average speed of the accelerating segment is only v2.
Umm… no, that equation still applies. It does represent the momentum of that system. What does not work is then expecting the momentum to be conserved, unless we represent the momentum carried away by (or brought in with) the mass change as an external impulse.PeroK said:If ##m## is taken to be constant, then it's a minor restatement of the law in terms of momentum.
It doesn't apply if mass is entering or leaving the system.
I was trying to figure out how the energy ended up different using a force based approach. The detailed analysis of internal energy within the rope is outside the scope of the this homework.haruspex said:Sure, but to make that work you have to assume perfect elasticity and take the rope to have been originally in a vertical stack of zero height, i.e. a spring of zero relaxed length.
(Even then, could there be persistent vertical oscillations? Analysis as a massive spring might settle this.)
I've provided several references that show that it does not apply in general.haruspex said:Umm… no, that equation still applies.
Sorry, for some reason I completely misread the referenced equation as being ##\dot{ \vec p}=\frac d{dt}(m\vec v)##. Bizarre.PeroK said:I've provided several references that show that it does not apply in general.
Unfortunately it is not.PeroK said:The detailed analysis of internal energy within the rope is outside the scope of the this homework.
