Work Question (Pulling a chain on the Moon)
In summary: I get it nowIn summary, the conversation discussed a situation at a lunar base where a uniform chain hangs over the edge of a horizontal platform. A machine exerted 1.0J of work to pull the rest of the chain onto the platform. The chain had a mass of 2.0kg and a length of 3.0m. Using the equations ##ρ_{chain}=M/L## and ##W_g=-\Delta U_g##, the conversation attempted to find the initial length of chain hanging over the edge. It was determined that the answer is 1.36m.
Arman777
Insights Author
193
At a lunar base,a uniform chain hangs over the edge of a horizontal platform.A machine does ##1.0J## of work in pulling the rest of the chain onto the platform.The chain has a mass of ##2.0 kg## and a length of ##3.0m##.What length was initally hanging over the edge ? On the moon,the gravitational acceleraiton is ##\frac 1 6## of ##9,8 \frac {m} {s^2}##
##ρ_{chain}=M/L##
##W_g=-ΔU_g##
Let's suppose ##L_1## length is needed to pull.
So chain density will be ##ρ=\frac {2kg} {3m}=0.66\frac {kg} {m}##
The mass of ##L_1## is## L_1ρ=M_1##
The gravitational work on ##M_1## is ##W_g## which its ##-M_1gL_1=1J##
##(L_!)^2ρg=6J##
which ##L_1=1.05m## but the answer is ##1.4m##
Theres a "-" sign which makes me uncomfortable.Also I am making wrong at some point
Hint: If the length hanging over the edge is L, does every bit of the mass have to pulled up a height L?
Also, the work is done by some force pulling the chain up, so its sign would be +. (It's work against gravity, not by gravity.)
Here what I did
##(M_1dm)g(L1-dl)=W-dw## dw is zero and ##(M_1-dm)=(L_1-dl)p##
Is this true ?
yeah that's right but the work done by gravity on the chain is negative .The work done by machine to the chain is positive.Thats why I confused
Arman777 said:
Here what I did
Is this true ?
Not quite sure what you're doing here. Are you trying to set up an integral?
Hint: If some extended object changed height, what point on the object would you track to compute its change in gravitational PE?
The work done by the machine equals the change in gravitational PE; both are positive.
yep I see now
I was...If the lengh decreases a bit what would be happen
Ok let me try again
I found 1.36m by usig this equation
##(L_1)^2ρg=12J##
Is it true ?
##(L_1)^2ρg=12J##
Is it true ?
Don't just toss out an equation; show how you got the equation.
Consider a mass element dm of the hanging section of the chain. If the length hanging is L, what is the average distance that each mass element must be lifted to get to the platform?
##M_1a_gH=1J##
##H=\frac {L_1} {2}##; The center of mass of ##M_1## moves this much.
##M_1=L_1ρ##
so,
##(L_1)ρ\frac {g} {6}\frac {L_1} {2}=1J##
Arman777 said:
##M_1a_gH=1J##
##M_1=L_1ρ##
so,
Perfect!
Average distance will be ##\frac {L_1} {2}##
##∫\frac {L_1} {2}dmg=1J## from 0 to M and so This is true I am sure but If I wanted to convert it to ##dl## ,
##dm=dlρ## so ;
##∫\frac {L_1} {2}gρdl## from 0 to ##L_1p## ?
Once you use the center of mass there's no need to integrate. But if you do, you'll get the same answer.
Oh ok thank you
Related to Work Question (Pulling a chain on the Moon)
1. How does pulling a chain on the Moon differ from pulling a chain on Earth?
On the Moon, the force of gravity is approximately one-sixth of that on Earth. This means that it would take less effort to pull a chain on the Moon compared to on Earth.
2. Would pulling a chain on the Moon be easier or harder than pulling a chain on Earth?
Pulling a chain on the Moon would be easier because of the lower force of gravity. However, the lack of atmosphere and lower friction on the Moon's surface may make the chain more difficult to grip and manipulate.
3. How would the weight of the chain affect pulling it on the Moon?
The weight of the chain would still play a role in pulling it on the Moon, but it would be less significant due to the lower force of gravity. This means that a heavier chain may be easier to pull on the Moon compared to on Earth.
4. Would the length of the chain affect pulling it on the Moon?
The length of the chain would not have a significant impact on pulling it on the Moon. As long as the chain is within reach and can be gripped, the lower force of gravity would make it easier to pull regardless of its length.
5. Is there any other factor that would affect pulling a chain on the Moon?
The lack of atmosphere on the Moon would also play a role in pulling a chain. Without air resistance, the chain would experience less drag, making it easier to pull. Additionally, the lower friction on the Moon's surface may also affect the ease of pulling the chain.
9K
