Work required to concentrate a dilute solution
  • Thread starter staceybiomed
  • Tags
    Work
In summary, the conversation discusses the calculation of work required to concentrate a dilute sucrose solution and compares the results to an ideal solution. The problem involves starting with a 10 wt % sucrose solution and increasing it to 30 wt %, with a basis of 1 kg of the 10 wt % solution. The conversation also mentions the use of activity coefficients and Gibbs free energy in the solution. The speaker is seeking help with understanding the connection between work and Gibbs free energy.
staceybiomed
I am not really good at using the specials characters, etc so please forgive me!
a) Calculate the work required to concentrate a dilute sucrose solution. Assume that we begin with 10 wt % solution of sucrose in water and we want to end with a 30 wt % sucrose solution. Pick a basis of 1 kg of 10 wt % solution and express answer in Joules.
b) Compare your to answer to that which would be obtained if you assumed the sucrose-water solution to be ideal (i.e. where the activities are set equal to the mole fraction)
T of separation = 20C
MW of sucrose = 342.3 g/mol
For 10 wt% sucrose solution: molality (moles sucrose/kg H2O) = 0.3249, mole fraction H2O = 0.99419, Activity of water = 0.99393
For 30 wt% sucrose solution: molality = 1.253, mole fraction H2O = 0.99794, activity of water = 0.97596
non-ideal:
G = [tex]\Sigma(xi * [tex]\gamma[/tex])[/tex]
where [tex]\gamma[/tex] is activity coefficient
ideal:
G = [tex]\Sigma(xi)[/tex] + RT * [tex]\Sigma(xi*ln xi)[/tex]
I know that if we start with 1 kg of 10 wt % solution, I start with 0.100 kg of sucrose (also known as 0.292 moles) and the mass/moles of sucrose remains constant during concentration. It is just the amount of water that reduces (goes from 0.900 kg to 0.233 kg in 30 wt % solution). Also, the solution mass goes from 1 kg to 0.333 kg.
I think that if I can get Gibbs F.E. for non-ideal by just adding the (mole fraction * activity coefficients) at each concentration but not sure if that is the right way to start. Also, I'm not sure how to connect work to Gibbs free energy.
Please help!
P.S. I have 2 other problems that I need help on so stay tuned... :-)
I am still looking for help on this question...please help me!
Hello,
Thank you for your question. I am happy to help you with this problem.
To begin, let's define some terms and equations that will be useful in solving this problem. The work required to concentrate a solution can be calculated using the following equation:
W = ΔG = ΔH - TΔS
Where W is the work, ΔG is the change in Gibbs free energy, ΔH is the change in enthalpy, T is the temperature, and ΔS is the change in entropy.
In this case, we are dealing with a non-ideal solution, so we will need to use the following equation to calculate Gibbs free energy:
ΔG = Σ(xi * γ)
Where xi is the mole fraction of each component and γ is the activity coefficient.
Now, let's apply this to the problem at hand. We are starting with 1 kg of a 10 wt % sucrose solution, which means we have 0.100 kg of sucrose and 0.900 kg of water. We want to end up with a 30 wt % sucrose solution, which means we will have 0.300 kg of sucrose and 0.700 kg of water.
Using the given information, we can calculate the mole fraction of sucrose and water in both the initial and final solutions:
Initial solution:
Mole fraction of sucrose = 0.100 kg / 0.3249 mol = 0.308
Mole fraction of water = 0.900 kg / 0.3249 mol = 2.769
Final solution:
Mole fraction of sucrose = 0.300 kg / 1.253 mol = 0.239
Mole fraction of water = 0.700 kg / 1.253 mol = 0.560
Now, we need to calculate the activity coefficients for each component at both concentrations. This can be done using the following equations:
ln γ = -A ln(molality) + B molality + C
Where A, B, and C are constants that can be found in tables for different substances.
For sucrose:
Initial concentration:
ln γ = -1.044 ln(0.3249) + 0.006 molality + 0.048 = 0.021
Final concentration:
ln γ = -1.044 ln(1.253) + 0.
Related to Work required to concentrate a dilute solution
What is the definition of "Work required to concentrate a dilute solution"?
The work required to concentrate a dilute solution refers to the amount of energy or effort needed to increase the concentration of a solution by removing solvent or adding solute.
Why is work required to concentrate a dilute solution?
Work is required to concentrate a dilute solution in order to overcome the natural tendency of solute particles to spread out evenly in a solvent. This process is known as diffusion. In order to increase the concentration of the solution, energy must be added to the system to counteract the effects of diffusion.
What factors affect the amount of work required to concentrate a dilute solution?
The amount of work required to concentrate a dilute solution depends on the initial concentration of the solution, the desired concentration, and the volume of the solution. The type of solvent and solute also play a role in the amount of work required.
How is the work required to concentrate a dilute solution calculated?
The work required to concentrate a dilute solution can be calculated using the formula W = mRTln(C2/C1), where W is the work, m is the mass of the solvent, R is the gas constant, T is the temperature, C2 is the final concentration, and C1 is the initial concentration. This formula is known as the Gibbs free energy equation.
What are some practical applications of understanding the work required to concentrate a dilute solution?
Understanding the work required to concentrate a dilute solution is important in various industries, such as pharmaceuticals, food and beverage, and environmental science. It can help in the production of concentrated solutions for medications, flavorings, and water treatment. It is also essential in understanding osmosis and its effects on biological systems.
  • Thermodynamics
  • General Math
