Working out power loss in power lines: Multiple wires
In summary: I don't think so.In summary, the maximum power loss per km when using 10 possible combinations of wires is 129600 watts.
Roynish
Hey everyone,
This is quite a simple question, I think I'm just getting confused.
1. Homework Statement
Given Data:
Merlin: Resistance: 2 Ω / km, Maximum Current: 519
Pelican: Resistance: 1.5Ω/km, Maximum Current: 646
Penguin: Resistance: 4 Ω/km, Maximum Current: 357
Sparrow: Resistance: 11Ω/km, Maximum Current: 184
Swan: Resistance: 17Ω/km, Maximum Current: 140
Note: Maximum current that will pass through the wire is 360 A
State the maximum power loss per km for 10 possible combinations of wires.
Ploss=I²R
Total Resistance = 1/{(1/R1)+(1/R2)+(1/R3)..+(1/Rn)}
I'm not sure how current is divided up depending on the combination of wires.
First I tried to do 2x Merlin in parallel
Current is the same in components in parallel so:
Rtotal: [itex] (1/2 + 1/2)^-1 = 1 [/itex]
Ploss= I²R
[itex] = (360)^2 [/itex]
= 129600
Total Power loss; 129600x2= 259200 W
This is the same as just figuring out Merlin x1. Would I divide the current by 2 if I did 2x Merlin in series?
Also say I tried doing:
1x swan, 1x sparrow, 1x penguin
I have no idea what to do with currents. Add them together? Divide them up?Thanks for your help.
Hello Roy, welcome to PF :smile: !
For parallel wires, you know that the voltage is the same for each of the two. Uncle Ohm's law gives you the current ratios.
For two Merlins in parallel that means each of the wires carries only 180 Amps ! A lot less max power loss, therefore.[edit] Ah, now I see: combinations in this exercise means parallel combimations !
Oh! I thought current is the same in parallel rather than series, sorry my mistake.
Not necessarily I think. It can be in series.
So: Say I did 1x swan, 1x penguin in series.
Total Resistance: 17+4 = 21 ohms
Current: 360 A
Power loss: I²R
360 x 21
= 7560 Watts
Is this correct? I did not surpass the amount of maximum amount of current for each wire because together they can take a maximum current of 497. Is that correct? ie. if I have 2 wires in series with different max currents do I add them together to get the overall maximum current?
Sorry for the bother!
Thanks for the welcome ^_^
Edit: This is all per km of course
From the above statement, if seems that you can answer your own question below.
... ie. if I have 2 wires in series with different max currents do I add them together to get the overall maximum current?
Current: 360 A
Swan maximum is 140A, this must not be exceeded
NascentOxygen said:
Swam maximum is 140A, this must not be exceeded
oh? I thought that if I put it in series with penguin there will be a net maximum current of 140 + 357(penguin's max currrent) = 497 A
So if current is the same in each point in the series circuit...the overall max current should be the sum of the two wires' max currents...I assume...
I feel like I'm missing something here
In a series circuit the same current passes through each, just as water pipes in series carry the same water flow.
Okay, so the maximum current is different but the current flowing through each wire is the same. Gotcha. Okay say if I instead put Merlin in parallel with say pelican maybe I would not exceed the maximum current if current is split. How would I work out the current flowing through Merlin and in turn pelican? Extra information that probably will be helpful: 330, 000 V is supplied, may use up to 120 MW of power. These are the values I used to get the maximum current running through the wire. (I=P/V, 120 000 000/330 000= 363.6, simplified to 2 sig. figures; 360 A)
Attempt:
Current through Merlin: I = V/R
=330, 000/2
=165 000 A
Obviously this is wrong. Maybe I can use another formula: I = √PR
120 000 000 x 2 = 240 000 000
√240 000 000= 15491.93338
Obviously this is wrong as well. I'm just confusing myself even more now. This is something to do with the resistance since I didn't use resistance to work out the initial maximum current I think.
Current: 360 A
Power loss: I²R
360 x 21
= 7560 Watts
Is this correct?
Did you forget the 'squared' current? This would be the loss per 2km, so you'll probably express it as per km.
Are you sure you can use Swan in series with Penguin? It won't meet the 360A specification, if I'm reading this correctly.
The 300kV goes mostly to the distant load, whatever it is, and is not 'used up' by the resistance in these cables. So you don't use that figure to calculate a cable's power losses.
When you have two cables in parallel, their voltage is common, so currents are
I = I1 + I2 = V/R1 + V/R2
and the current sharing can be expressed
∴ I1 / I2 = R2 / R1
Sorry I forget to square it. So the answer would actually be 2721600 Watts. This is per 2km so I divide it by two; 1360800 W/km.
Yes that's correct. I'm wrong.
NascentOxygen said:
The 300kV goes mostly to the distant load, whatever it is, and is not 'used up' by these cables. So you don't use that figure to calculate cable power losses.
∴ I1 / I2 = R2 / R1
Wow thanks. So can I use the current divider rule: R1 current: Itotal * R2/(R1+R2)??
So again: Merlin in parallel to pelican
360 x 2 / (1.5+2)
=154.3
WHEW it works! Doesn't overcome mass current
SO: Total power loss
I²R Total Resistance: [itex] (1/2 +1/1.5)^-1 [/itex]
=6/7
[itex] (360)^2 [/itex] x 6/7
=111085.72
For per km divide by 2:
55542.86 W/km
I hope that's correct.
I doubt that final divde by 2. Probably leave it as per km of paralleled cable.
Okay thank you so much.
Edit: I have to put this on a graph cost per km (data is given) vs power loss per Km. Do I still leave it as power loss per km of paralleled cable or for the sake of comparison change it?
I would leave it as per km of parallelled cable, but it's just a scaling factor so shouldn't complicate comparisons.
Okay. Will do. Thanks!
Related to Working out power loss in power lines: Multiple wires
1. What is power loss in power lines?
Power loss in power lines refers to the amount of energy that is lost as electricity travels through wires from a power plant to its destination. This loss occurs due to factors such as resistance in the wires, distance traveled, and environmental conditions.
2. How is power loss calculated in power lines with multiple wires?
The power loss in power lines with multiple wires can be calculated using the following formula: P = I^2 x R x L, where P is the power loss, I is the current flowing through the wires, R is the resistance of the wires, and L is the length of the wires.
3. What factors affect power loss in power lines with multiple wires?
There are several factors that can affect power loss in power lines with multiple wires. These include the type and size of the wires, the distance between the wires, the current flow, the temperature, and the weather conditions.
4. How can power loss be reduced in power lines with multiple wires?
Power loss in power lines with multiple wires can be reduced by using larger wires with lower resistance, decreasing the distance between the wires, and implementing efficient transmission techniques such as using higher voltages.
5. Why is it important to reduce power loss in power lines?
Reducing power loss in power lines is important because it leads to more efficient energy transmission and distribution. This means that more electricity can reach its intended destination, resulting in lower energy costs and reduced environmental impact.
  • Electromagnetism
10K
