Working out the first and second derivative
In summary, the authors suggest that f'(x)=2x/〖(1-x^2)〗^2 and f"(x)=2 (1+〖3x〗^2)/〖(1-x^2)〗^3 for a) and b), respectively. However, they state that using the quotient rule may not work for this problem and suggest the use of the product rule instead.
Willjohnc
Let f(x)=x^2/(1-x^2 )
a) Find f'(x)
b) Find f"(x)
For the answer to a) they give f'(x)=2x/〖(1-x^2)〗^2
and for b) f"(x)=2 (1+〖3x〗^2)/〖(1-x^2)〗^3
Now after many rounds of trying i have not been able to get an answer remotely close to what they have given. i don;t know if it is due to me over working a simple problem or what. the same applies to b), taking the second derivative.
For a) i applied the quotient rule:
f(x)=x^2/(1-x^2 )
f'(x)=(2x(1-x^2)-(1-x^2)x^2)/(1-x^2)^2
then it stops there as i don't know where to proceed, i am not entirely sure if what i have done is correct but other methods result in something similar.
Then for b)
Using their answer and trying to work with it to see if i fared any better for the 2nd derivative proved that i was lost. any help with a) would be appreciated as it means i could work out b) and any similar problems in the future.
You seem to have made an error in applying the quotient rule. You should have
f'(x)=[g'(x)h(x)-h'(x)g(x)]/[h(x)]^2 where g(x)=x^2 and h(x)=1-x^2. After you differentiate h(x) where I suggested, multiply the resulting numerator all out and combine like terms.
I confirmed the answer to a) but I think the answer for b) should be
f"(x)=2 (1+3〖x〗^2)/〖(1-x^2)〗^3
Personally, I never use the quotient rule. Note that you can write any function that readily permits the quotient rule (i.e. f(x)=g(x)/h(x)) as f(x)=g(x)[h(x)]^(-1) and then apply the product rule. However, it is important to realize the inner workings of the quotient rule for problems that specifically call for its use (tends to happen a lot on calculus midterms//finals//what have you).
Thank you, for some reason something wasn't clicking.
Found using the product rule with these problems really simplifies them so, thanks again.
FAQ: Working out the first and second derivative
What is the first derivative?
The first derivative is the rate of change of a function at a specific point. It measures how fast the function is changing at that point.
How is the first derivative calculated?
The first derivative is calculated by finding the slope of a tangent line to the function at a specific point. This is done using the limit definition of the derivative or by using differentiation rules.
What is the second derivative?
The second derivative is the rate of change of the first derivative. It measures how fast the slope of the function is changing at a specific point.
How is the second derivative calculated?
The second derivative is calculated by finding the derivative of the first derivative. This can be done using the differentiation rules or by finding the derivative of the derivative using the limit definition.
What is the significance of the first and second derivative?
The first derivative helps us understand the behavior of the function at a specific point and whether it is increasing or decreasing. The second derivative helps us determine the concavity of the function at a specific point and whether it is concave up or concave down.
