Working Principle of Split Ring Resonators
In summary, split-ring resonators (SRRs) are structures made up of metal rings with splits, designed to have specific electromagnetic properties. They work based on the principles of electromagnetic resonance, similar to atomic models. The negative permeability at a macro level is caused by the interaction of the SRRs with electromagnetic waves in a specific frequency range. The capacitance forms within the SRRs and plays a role in their functioning. The current flow and electric fields within SRRs are complex and can be studied in more detail through technical articles and research papers.
abhiroop_k
42
What is the physical working principle of SRR's ?
How do they result in the negative permeability at a macro level?
(either of explanation or decent links will do!)
Thanks :biggrin:
Thanks :biggrin:
Read : http://en.wikipedia.org/wiki/Split-ring_resonator
i have gone through this. what i was looking for is the actual physics supporting the functioning of the srr. wiki merely states its structure and characteristics.
how is it equivalent to an atomic (magnetic) model and what actually causes the negative permeability within the given freq range?
where exactly does the capacitance form and what role does it play?
how exactly, is the current flow/elec fields within etc.?
That would be a lot technical.
May be this is what you are looking for:
http://esperia.iesl.forth.gr/~ppm/PUBLICATIONS/APLv84p2943.pdf
http://infoscience.epfl.ch/record/164853/files/060.pdf
Does this help ?
What is the function of the splits on each ring in SRR's ?
The precise idea of that is given in the Wikipedia article in the introduction part. Read it.
For more details, refer to the links I mentioned in my previous post.
Related to Working Principle of Split Ring Resonators
1. What is the working principle of split ring resonators?
The working principle of split ring resonators is based on the phenomenon of electromagnetic resonance, which occurs when an external electromagnetic field at a specific frequency induces a circulating current in a conductor. In split ring resonators, the conductor is split into two halves with a small gap, creating an LC circuit that can resonate at a specific frequency.
2. How do split ring resonators affect electromagnetic waves?
Split ring resonators affect electromagnetic waves by creating a strong magnetic response at a specific frequency. This can be used to manipulate and control the propagation of electromagnetic waves, such as in the design of metamaterials for advanced imaging and communication technologies.
3. What are the main applications of split ring resonators?
Split ring resonators have a wide range of applications, including in microwave and radio frequency technologies, where they are used to create filters, antennas, and sensors. They are also being explored for use in optical devices, such as for enhancing the performance of solar cells and creating new types of lenses.
4. Can split ring resonators be used for wireless power transfer?
Yes, split ring resonators can be used for wireless power transfer. By designing the resonant frequency of the split ring resonator to match the frequency of the external power source, the resonator can efficiently absorb and transfer the energy to a nearby receiver. This technology has potential applications in wireless charging for electronic devices and inductive power transfer for electric vehicles.
5. Are there any limitations to the working principle of split ring resonators?
One limitation of split ring resonators is that they only work at a specific resonant frequency, which can be a disadvantage in applications where a wider range of frequencies needs to be manipulated. Additionally, the performance of split ring resonators can be affected by environmental factors, such as temperature and humidity, which can alter the resonant frequency and decrease their efficiency.
  • Quantum Physics
10K
  • Classical Physics
