Would 2x 5.5" Fans attached to Wye Duct pull efficiently?
  • Thread starter Thread starter Ambience
    Pull Wye
Using two 5.5" computer fans rated at 82 CFM each with a wye duct fitting for air exhaust in a grow tent is feasible, but may not be the most efficient setup. The airflow could be restricted due to pressure drops in the shared duct, meaning the combined airflow won't necessarily equal the sum of the individual fans. Dedicated ducting for each fan is recommended for optimal performance. While the wye fitting could simplify installation, it may not provide the desired airflow efficiency. Ultimately, the choice of setup depends on specific requirements and constraints of the grow tent environment.
Ambience
TL;DR Summary
Are there issues having 2 exhausting fans attached to a wye duct?
Hello everyone. I'm an idiot and have a question.I want to do something like this:
I want to use 2 computer fans (140mm/5.5" and rated @ 82 CFM each) attached to a wye connector to exhaust air.
Can it be used in this nature? Usually it's one big fan exhausting from multiple areas. This probably seems backwards, but was curious.
My other option is having each fan with their own dedicated ducting with no wye fitting.
Why am I doing this? Using it in a grow tent where I need to exhaust air. I currently have the 4" ducting and 2 fans. All I would need is to buy a wye duct fitting. Doing it this way would save me from having to rig up another dedicated duct for it's own single fan (when I could just attached 2 to a wye) or purchase a more powerful fan with the same size or bigger ducting.
Thanks for any feedback. Take care.
Can you do it? Sure, no problem.
Is it efficient? Compared to what?
The fan(s) are restricted somewhat by the pressure drop in the duct(s) though. So fans with larger (or multiple) ducts work better than smaller ducts. You won't get twice the airflow by adding a second fan if they share an upstream duct.
In general, detailed solutions are difficult and depend on lots of details in your setup.
There are many web sites that can help you understand more; like these:
https://www.boydcorp.com/resources/temperature-control/heat-exchanger-fan-selection.html
https://www.cuidevices.com/catalog/...-a-fan-for-forced-air-cooling-cui-devices.pdf
https://www.orientalmotor.com/products/pdfs/2015-2016/H/Cooling_Fan_Selection_Calculations.pdf
Thanks. I will do each fan with it's own single ducting setup.
