- #36
Topher925
- 1,566
- 7
mgb_phys said:A modern engine is already a pretty complex system, I don't see this adds much.
You can't even compare the complexity of a regular modern engine to that of an HCCI engine the complexity is so great. With modern engines you really only need to control spark timing, fuel flow, and throttle, along with some ancillary devices like cooling. With HCCI, you need to control EVERYTHING. Its not like a regular engine where you have fixed valve timing. The valves need to be controlled independently and with a very high degree of accuracy which means high speed/pressure hydraulics instead of cam shafts. Temperature sensors and pressure transducers are required all over the place and not to mention the computer hardware to run all this.
