Would Earth not be seen flashing from space like a lighthouse?
  • Thread starter Thread starter earthlingjeff
    Earth Space
Earth would not appear to flash like a lighthouse from space; instead, it would be seen as a bright, relatively constant light due to its spherical shape and the way it reflects sunlight. The planet reflects light in all directions, with land areas exhibiting higher albedo than oceans, resulting in minimal variations in brightness. Cloud cover significantly influences the overall reflectivity, covering a large portion of the Earth's surface. Observations of Earth from distant planets would reveal slight changes in brightness, but these would be subtle. In contrast, the detection of extraterrestrial civilizations might rely on narrowband RF signals from satellites, which could be interpreted as a "lighthouse" effect.
earthlingjeff
TL;DR
Earth Lighthouse
Can anyone tell me if this would be correct? Would Earth not be seen flashing from space like a lighthouse to a distant planet when it reflects oceans and then DMS as the sons reflection per perspective travels across land then back to Ocean then back to land?
I'm sure it probably says that somewhere but I've never heard.
Thank you very much
Earth, like the rest of the planets in the solar system we can see from Earth, does not reflect light like a disco ball (a ball of mirrors). The reflections go in all direction, so you can see the entire side of the planet facing you, even the parts not directly facing.
Welcome to PF.
Viewed from another planet in the solar system, the variation in cloud cover would be noticed. The specular reflections from the ocean surface would be confused by the water waves.
Since the Earth is close to spherical, it will reflect and scatter sunlight in all directions, not like a flat mirror or Earth.
Viewed from outside the solar system, the brightness of the Sun would dominate the variations in brightness of the Earth.
Likes Klystron and FactChecker
What if you were an alien measuring the intensity of light from distant stars and planets with vary from time to time and not seem like a constant
earthlingjeff said:
TL;DR Summary: Earth Lighthouse
Thank you very much
It's a bit more complicated than that. The two areas (ocean and land) have different types of reflection, specular and diffuse.
For water, you have specular, which means that the light hitting that part of the surface not directly facing you is reflected away, and you mostly see a small specular highlight.
Land has diffuse reflection, and light is scattered more upon reflection, meaning it looks more evenly lit.
In the above images, I used a darker shade of green for land, and it still looks brighter overall than the oceans.
The end result is that the albedo( the amount of light reflected) for the ocean is 0.05-0.1, while for land, it is 0.1-0.4. In other words, land would reflect more total light than ocean.
Cloud cover, also diffuse, covers roughly 2/3 of the total surface, and ~90% of the oceans. This makes up for a great deal of the albedo difference between ocean and land areas.
The upshot is that you'd see only tiniest of variation( if any) in the Earth's brightness as it rotates.
Likes PeroK and russ_watters
Planets about other stars do not reflect sufficient light from their star to be seen from Earth. The planet's brightness may also change throughout their year, as they wax and then wane. The way we detect planets orbiting other stars is done when the planet eclipses their star's light, so we see short drops in the star's brightness. The brightness of a star blinds us to direct view of the surrounding planets.
Likes sophiecentaur
The closest thing I can think of to a "lighthouse" effect that might be detectable would be the uplink RF comm beams to satellites. The ones to geostationary satellites are probably the strongest, since they need to travel farther to hit their targets. They are narrowband, so if a civilization on another planet not too far away were searching for other civilizations, it would be logical for them to observe other solar systems with narrowband RF receivers to improve the Signal/Noise ratio of their observations...
https://www.esa.int/Applications/Connectivity_and_Secure_Communications/Satellite_frequency_bands
Edit/add -- the first geostationary satellite for Earth was launched in 1964, so we've been doing this "lighthouse" beaming for close to 60 years now. A blink of an eye in Astronomical terms... :wink:
https://en.wikipedia.org/wiki/Geosynchronous_satellite
As a historical side note: In the early days after Pluto's discovery, and when it was still just a fuzzy dot in telescopes, there was a question as to why it was so small. They even considered the possibility that it was larger, but was an icy world with a relatively smooth surface, and what we were seeing was the specular highlight glinting off of it.
  • · Replies 98 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 46 ·
11K
