Would planets fall out of orbit when gravity has a speed?
In summary, the conversation discusses the concept of gravity having a speed and how it affects the movement of planets in their orbits. The discussion also touches on the role of relativity and frames of reference in understanding this concept. The conversation ends with a suggestion for further reading on the topic.
Erribert
As I understand it, Newton considered the influence of gravity between two objects to be instantaneous.
Now it would appear that gravity has a speed limit. If the Earth is influenced by the sun from where it was 8 minutes ago, how does the Earth keep up with a traveling sun?
Does relativity and frames of reference play a mathematical role in this? What about simple vector analysis?
Thank you in advance.
Astronomy news on Phys.org
Gravity has a speed. It is the speed of light, which is fast, but nevertheless a certain finite number. The planets are free falling in space. They basically all fall into the sun, but they are so fast, that they constantly miss it. And this makes the orbits. Not only of planets, but of our satellites as well. It's a bit like jumping over a puddle. If you're fast enough you won't fall into it.
Likes Erribert and Fervent Freyja
Gravity has a speed, and planets do not fall out of orbit, so the answer to your question is "no:".
Likes stefan r and Fervent Freyja
Very clever. However the correct answer could be that gravity acts instantaneously. Or, maybe you are pulling my leg?
What instruments measure the speed of gravity? Do such instruments have algorithms that are based on finding such speed to be that of light? If so, I would call that unethical science.
To return your answer in kind: the Earth exists so that proves there is a god that travels at the speed of light. Have a go at disproving that theory.
<Moderator's note: Personal comments removed.>
So I assume you are using the extraterrestrial fourth dimension, and those pictures of wells around matter. Okay, but isn’t that complete conjecture?
In Einstein’s colleagues derivation of the field equations, their first step was to claim that gravity existed without mass. That is, they arbitrarily set mass to zero. Is there proof that there is a field that could exist in a universe without mass?
Most people think that gravity and mass are related, but not Einstein’s group. Reality is not a set of equations on a blackboard that we can just step into. There is a big difference between a description of a thing and the thing itself. Ever try to step into a map of Argentina so you could be in that reality.
I am just looking for strong experimental data on gravity’s speed. We trust in God, all others must produce data.
Thank you for your answer. I am familiar with the setting you propose. What you left out was that the sun is moving. By the time Pluto gets its gravitational signal, it would seem like the sun is long gone. How is this explained. Simple vector analysis seems to disprove that gravity has a finite speed. But, what do I know. I am a simple biophysicist.
Cheers
I have no idea where you are getting this from. This and your posts in other threads indicate that you know a lot less than you think you do about the subjects you are posting from. You really need to build a better understanding.
FAQ: Would planets fall out of orbit when gravity has a speed?
What is the speed of gravity?
The speed of gravity is approximately 299,792,458 meters per second, which is equivalent to the speed of light.
Can planets fall out of orbit if gravity has a speed?
No, planets will not fall out of their orbits due to the speed of gravity. The speed of gravity is constant and does not affect the stability of planetary orbits.
How does the speed of gravity affect the motion of objects in space?
The speed of gravity affects the motion of objects in space by determining the rate at which gravitational forces are transmitted between objects. This means that the strength of the gravitational force can change over time as the distance between objects changes.
Is the speed of gravity the same for all objects?
Yes, the speed of gravity is the same for all objects regardless of their mass or size. This is because the speed of gravity is determined by the fundamental properties of space and time, not by the objects themselves.
How was the speed of gravity calculated?
The speed of gravity was first calculated by Sir Isaac Newton in the 17th century using his law of universal gravitation. Later, Albert Einstein's theory of general relativity provided a more accurate calculation of the speed of gravity by incorporating the effects of space and time on gravitational forces.
