Would the opposite of a perfect power be called a "root"?
In summary, the conversation revolves around finding an official name for the class of integers that are not perfect powers, which are numbers that can be expressed as xn where x and n are both integers greater than 1. The term "perfect power" is well-known, but there does not seem to be a widely accepted term for the opposite class of integers. Suggestions include "perfect nth root" and "integer," but these do not quite capture the concept. One suggestion is to use the complement of the OEIS sequence A001597, which lists numbers that are not perfect powers. Another suggestion is to use the GCD (greater common divisor) of the exponents of all the powers of the primes in a number's prime decomposition to determine if
Ventrella
29
I would like to know if there is an official name for the class of integers that are (not) perfect powers. A perfect power is a number that can be expressed as xn, where x and n are both integers > 1. I have been calling these integers "roots" - since they do not have any integer roots of their own, and they are the roots of their own integer powers.
I am actually exploring the Gaussian integers, and I assume these concepts apply equally to the Gaussian integers as they do to the rational integers.
Thanks!
-Jeffrey
Mathematics news on Phys.org
The solution to f(x)=0 is called a "root" of the equation, whether f(x) is a power or anything. It can also be called a "zero" of the equation.
If y = x^n, then we say that "x is the nth root of y" even if x is not an integer.
If x is an integer, then x is called a perfect nth root.
Likes Janosh89
Thanks for the suggestion, Simon!
"Perfect nth root" makes sense. It's better than "root".
I would still like to find a way to express this class of numbers without having to reference an integer (i.e., "nth") of which it is a perfect root - since there are infinitely many n's. I think of these integers as analogous to the primes, except they are primitives of integer exponentiation instead of primitives of integer multiplication. Each of these integers is the first (x1) in an infinite series of perfect powers...and they are not members of any other set. If I'm not mistaken, the union of these sets is the set of all integers.
There is a single-word name for a general perfect root ... it is called "integer".
Maybe I didn't explain myself. I'm talking about integers that do not have perfect roots.
Every integer x has a perfect root ##\sqrt{x}##, for example.
Hello mfb,
I believe you are incorrect.
You say that every integer has a perfect root. When you say "perfect" I assume that means integer. Of course every integer has roots, but not all of them are perfect (integers). The roots of integers are either integers or real (in fact, if they are not integers, they are actually irrational: https://proofwiki.org/wiki/Nth_Root_of_Integer_is_Integer_or_Irrational ).
If my question has no answer, then that's fine, but please read my question:
"Is there a name for the class of integers that are not perfect powers?"
For instance:
x = 125 is a perfect power (it can be expressed as rn, where r = 5 and n = 3 (both integers > 1))
x = 25 is a perfect power (it can be expressed as rn, where r = 5 and n = 2 (both integers > 1))
But x = 5 is not a perfect power (it cannot be expressed as rn, where r and p are integers > 1.
The first entries of this unnamed set would be:
0, 1, 2, 3, 5, 6, 7, 10, 11, 12, 13, 14, 15, 17, 18, 19, 20, 21, 22, 23, 24, 26, 28
The missing integers from this set are:
4, 8, 9, 16, 25, 27... (the perfect powers).
I am concluding that there is no official or agreed-upon name for this class of integers. Also, I cannot find that sequence in http://oeis.org. Maybe I'll add it.
Thanks,
-j
"Perfect powers" I've heard of, as 4 and 9 are perfect squares (of 2 and 3), and 64 and 125 are perfect cubes (of 4 and 5). I've not heard of the term "perfect root," or a distinction between a root of, say ##x^2 = 16## or ##x^2 = 17##.
I suppose. For example, in the Gaussian integers, -1 = -1 + 0i is the square of 0 + i, and 1 = 1 + 0i is the fourth power or 0 + i. All of these are Gaussian integers.
Likes Janosh89 and Ventrella
Ah, you require the root to be an integer.
So you are looking for the complement of oeis:A001597. "Not a perfect power" should do the job.
Likes Janosh89 and Simon Bridge
What you are looking for is: all the numbers for which the GCD (greater common divisor) of the exponents of all the powers of the primes in their prime decomposition is greater than 1. By definition the prime numbers (do not) belong in this list.
Hi dagmar,
Could you elaborate? Perhaps you could decompose your definition so I can understand the component parts. Specifically, I don't understand: "...the exponents of all the powers of the primes in their prime decomposition..."
I don't see how prime numbers are involved here. But if you are correct that prime numbers are involved non-trivially, that would be interesting.
Thanks!
-j
Likes dagmar
Yup, I know my English is terrible, :cry:
$$ n=p_1^{r_1} p_2^{r_2}...p_n^{r_n} $$ is prime decomposition of n. $$GCD(r_1,r_2,...,r_n)>1$$
GCD=2 => Number Perfect Square, GCD=3 => Perfect Cube, etc.
Sorry. Goodday.
Related to Would the opposite of a perfect power be called a "root"?
1. What is a perfect power?
A perfect power is a positive integer that can be expressed as the product of two or more positive integers raised to some integer power. For example, 8 is a perfect power because it can be expressed as 2^3, while 15 is not a perfect power because it cannot be expressed in this form.
2. What is the opposite of a perfect power?
The opposite of a perfect power is a number that cannot be expressed as the product of two or more positive integers raised to any integer power. These numbers are often referred to as prime numbers or prime powers.
3. Is the opposite of a perfect power also known as a "root"?
Yes, the opposite of a perfect power is commonly referred to as a "root" because it is the inverse operation of a perfect power. Just as a perfect power is a number raised to a power, a root is a number that is raised to a power to get the original number.
4. How does the concept of roots relate to perfect powers?
The concept of roots is directly related to perfect powers, as they are essentially inverse operations. For example, the square root of a perfect square will always result in the original number, and the cube root of a perfect cube will also result in the original number.
5. Can the opposite of a perfect power be a negative number?
No, the opposite of a perfect power cannot be a negative number. This is because a negative number cannot be expressed as the product of two or more positive integers raised to any integer power. Additionally, the concept of roots does not apply to negative numbers, as there is no real number that can be raised to a negative power to result in a negative number.
  • General Math
  • General Math
  • General Math
