Would the velocity of a fluid increase right after exiting a pipe into open air?
In summary, the conversation discusses the behavior of an inviscid fluid flowing in a pipe with a higher static pressure than atmospheric pressure. The dynamic pressure is expected to increase after the fluid exits the pipe, but there is confusion about the decrease in static pressure and its effect on the total energy and velocity distribution of the fluid. It is ultimately concluded that with an inviscid flow, there can be no pressure gradient and the static pressure cannot be greater than atmospheric.
dddoi
If you have an non-viscous incompressible fluid flowing in a pipe whose static pressure is higher than atmospheric pressure, then after exits the pipe will the dynamic pressure increase? The static pressure of the fluid right after exiting should decrease because it should be equal to the atmospheric pressure, so since the total pressure should stay the same the dynamic pressure would increase.
The increase in dynamic pressure implies an increase in the velocity the fluid, which seems to spell trouble because that would mean the flow rate inside the pipe is lower than the flow rate outside the pipe.
Any help would be greatly appreciated!
The static fluid pressure inside the pipe near its exit is atmospheric. What made you think that the static pressure is discontinous? Fluid pressure is a continuous function of spatial position.
My bad, my poor wording may have suggested that but I didn't think that. Regardless, doesn't the dynamic pressure near the exit still increase? A few centimeters from the end of the pipe, the static pressure is the atmospheric pressure so the dynamic pressure is higher, right? But in order for the volume flow rate to be the same there and somewhere inside the pipe, the cross-sectional area must be lower. The cross-sectional area doesn't seem to decrease, rather it increases which means my reasoning went awry somewhere but I can't see where.
Assuming no losses in the system, such as friction within the pipe, and no changes in temperature, density, ... , and a pipe with constant cross sectional area, then mass flow and fluid velocity should be constant within the pipe. If the pressure decreases from above ambient to ambient near the end of the pipe, what accounts for the decrease in total energy as the fluid approaches the end of the pipe (where is that energy going)?
Can the mass flow be distributed over the cross sectional area so that some parts of the fluid move slower while other parts move faster, in such a manner that the overall mass flow remains constant, but the velocity distribution results in an increase in dynamic pressure while the static pressure decreases? For a fluid with no viscosity, I'm wondering if such a velocity distribution could be determined.
For an inviscid fluid, the pressure in the pipe is not decreasing along the pipe.
For an inviscid fluid, the velocity profile in the pipe is flat.
What about the velocity just outside the pipe? Is the higher because of the decrease in static pressure? Or is it the same?
As I said, the static pressure does not decrease. I don't know how may different ways there are to say this.
I'm confused, assuming the static pressure within most of the pipe is greater than atmospheric, then where does the static pressure decrease to atmospheric, or is it impossible for an inviscid fluid to have a static pressure within the pipe greater than atmospheric ?
It's an impossible assumption because with invincible flow there can be no friction in a pipe, so no way for there to be a pressure gradient. But either way (even with viscous flow/drag), the pressure at the outlet is atmospheric.
Yes. It's impossible unless the pipe diameter is decreasing before the exit.
With a viscous flow (at least on the part of the air outside the pipe), it would seem that the entrainment of the air just beyond the end of the pipe could cause the affected air's static pressure to go above atmospheric and return to ambient somewhere beyond the end of the pipe.
This effect would be very insignificant; I have never seen it included in the analysis of exit effects for viscous flow. For viscous flow, the main exit effect is the transition from the parabolic velocity profile inside the pipe to a flat velocity profile beyond the tube exit. This gives rise to an additional pressure drop, equivalent to an additional tube length on the order of about one tube diameter. Fluid inertia interacts with this and leads to the so-called vena contracta effect.
Consider the case of a ducted fan with no taper in the tube (some model aircraft ducted fans are setup this way). My understanding is that the pressure in the tube ahead of the fan is lower than atmospheric and the pressure in the tube behind the fan is greater than atmospheric. The pressure in the tube would decrease due to friction, but unless the tube was fairly long, the pressure would remain above atmospheric until very near the end of the tube where the flow could get complicated (turbulent) due to interaction with the free stream air.
That's not what would happen. After the fan, the static pressure would decrease linearly from the value exiting the fan to atmospheric pressure at the tube exit.
Likes russ_watters
Related to Would the velocity of a fluid increase right after exiting a pipe into open air?
1. How does the velocity of a fluid change after exiting a pipe into open air?
The velocity of a fluid will increase right after exiting a pipe into open air. This is because the fluid is no longer confined by the walls of the pipe and is able to spread out into a larger area, causing an increase in speed.
2. Is there a specific formula for calculating the velocity of a fluid after exiting a pipe into open air?
Yes, there is a specific formula called the Bernoulli's equation that can be used to calculate the velocity of a fluid after exiting a pipe into open air.
3. What factors can affect the velocity of a fluid after exiting a pipe into open air?
The velocity of a fluid after exiting a pipe into open air can be affected by factors such as the diameter of the pipe, the pressure inside the pipe, and the density of the fluid.
4. Can the velocity of a fluid decrease after exiting a pipe into open air?
Yes, it is possible for the velocity of a fluid to decrease after exiting a pipe into open air. This can occur if there is a decrease in pressure or if there are obstructions in the path of the fluid.
5. How does the shape of the pipe affect the velocity of a fluid after exiting into open air?
The shape of the pipe can affect the velocity of a fluid after exiting into open air. A narrower pipe will cause the fluid to exit at a higher velocity, while a wider pipe will result in a lower velocity. This is due to the conservation of energy principle.
15K
  • General Engineering
  • Mechanical Engineering
