Guiwee
- 2
would time stand still at center of earth?...or at least be really slow
Guiwee said:would time stand still at center of earth?...or at least be really slow
heldervelez said:The field is maximum at surface.
Nabeshin said:Time will indeed run slower at the center of the Earth than at the surface. This effect is due to the fact that large gravitational potential wells lead to a slowing of time with respect to other observers. For an object like the earth, however, one cannot expect the effect to be detectable by humans, but would be measurable by sensitive instruments.
Caveat: Presumably those on the surface of the Earth are rotating with it, and this rotational velocity also leads to a slowing of time (Our bloke at the center is probably not moving). The two effects compete, then.
George Jones said:I made an idealized GR calculation of this in
https://www.physicsforums.com/showthread.php?p=1543402#post1543402.
heldervelez said:quoting from that post
"If an observer on the Earth's surface uses a telescope to look down a tunnel to a clock at the Earth's centre, he will see his clock running faster than the clock at the Earth's centre."
quoting from http://en.wikipedia.org/wiki/Gravitational_time_dilation"
"The clocks that traveled aboard the airplanes upon return were slightly fast with respect to clocks on the ground."
As seen above to be at the center of the Earth is equivalent to be at an infinite distance of the Earth.
Do I see a contradiction?
There is a difference between gravitational acceleration and gravitational potential. The time dilation (in a stationary spacetime) depends on the gravitational potential, not the gravitational acceleration. So the fact that the gravitational acceleration is zero at the center and at infinity is not relevant.heldervelez said:As seen above to be at the center of the Earth is equivalent to be at an infinite distance of the Earth.
heldervelez said:quoting from http://en.wikipedia.org/wiki/Gravitational_time_dilation"
As mentioned earlier, the clock at the centre of the Earth would look slower if the Earth was not rotating. You have to take both gravitational and velocity effects into account.heldervelez said:quoting from that post
George Jones said:If the Earth is modeled as a constant density, non-rotating sphere, then Schwarzschild's interior solution can be used.
No, time would not actually stand still at the center of the Earth. It is a common misconception that time would stop due to the intense gravitational pull at the Earth's core. In reality, time is affected by gravity, but it would still continue to pass.
Some people believe this because of Albert Einstein's theory of relativity, which states that time and space are relative to the observer's perspective. At the center of the Earth, the gravitational pull would be so strong that it would theoretically cause time to slow down, but it would not stop completely.
According to Einstein's theory of relativity, gravity can cause time to pass at different rates depending on the strength of the gravitational field. The stronger the gravity, the slower time would pass.
No, there is no place in the universe where time would actually stand still. Even at the event horizon of a black hole, where gravity is extremely strong, time would still continue to pass, albeit at a very slow rate.
Time dilation is a phenomenon predicted by Einstein's theory of relativity, where time passes at different rates for objects in different gravitational fields. This means that time would appear to pass slower at the center of the Earth compared to the surface due to the difference in gravitational pull.
