Wrist Pain from Writing Constantly
In summary: I try to, but it turns into a mess of big x's and scribbling.Perhaps you can listen more and record the class to fill in where notes are lacking.I usually use a mechanical pencil with a small lead, and I find that I need to use less force to write.
quantum_smile
I'm taking several physics/math courses this term, and I have no choice but to be writing constantly while taking notes and doing problem sets. My handwriting is very messy unless I grip my (mechanical) pencil tightly, and that ends up causing my wrist to start hurting (which has been a slight problem in the past, but never persistent like it is now). It doesn't hurt enough to prevent me from writing, but I'm worried because it's starting to get worse, and I can basically never give it a break because of my classes.
Does anyone else ever have this problem? Or do I just press my pencil down way too hard?
I just use a pen.
Sometimes my work has a few things scratched out here and there, but I don't mind.
You must be incredibly smart to always be able to do math and physics problems in pen. D:
If you have a ipad you could try the notability app to take notes. The trick is to activate the recording and to jot down simple one word, a number like 1,2,3... or even an underline on separate lines when the prof said something of interest. Later you can tap the underline and the recording will jump to what the prof was saying at that moment and then you can fill in the details. Notability has other cool features too. Also periodically as in daily or weekly, send the notes to yourself as backup.
I've never tried this yet but it seems feasible but you have to be willing to relax and listen instead of writing everything the prof says, does and writes on the board. It also helps to read the chapter under discussion so as not to rewrite it again as the prof lectures.
I always found it odd, over here we use pencils just until we learn how to write without mistakes.
After that it's all pen. I only use pencils to add notes in textbooks. (fix mistakes or improve the notes later)
Another thing that might help is use some sort of support (don't know if it exists) for you wrist as I suspect you cramp your wrist.
I prefer a tight grip also. You may want to look into Pencil pillows made from gel. They are comfortable if you are going to be writing for extended periods of time. I use them for my finger tips where I grip the pencil rather than my wrists. It may be worth a try.
Medicol said:
I recommend step 3: use a softer lead pencil... Go to office depot or staples & buy all the levels of soft lead... Then start with the softest & work your way up a level if it's too soft... Remember, the soft lead means you use less pressure to write...
I had this problem too & I can say the exercises definitely help... But when the pain gets so bad, you HAVE to stop and take a break even if just for the weekend.
I use a mechanical pencil now too, but get the type with the smallest diameter lead possible; that way you get a greater lead-onto-paper pressure while using less hand-onto-pencil force.
(Just think of the physics at play here!)
: wink :
Sounds like carpool tunnel syndrome
Where is this magical place, where no one writes without making mistakes?
Let me rephrase that, when we can write 5 sentences without an error.
Otherwise I just scribble over wrong stuff.
Related to Wrist Pain from Writing Constantly
1. What are the most common causes of wrist pain from writing constantly?
Typically, wrist pain from writing constantly is caused by overuse and strain on the muscles and tendons in the wrist. This can be due to writing with poor posture, using incorrect writing techniques, or not taking enough breaks while writing.
2. How can I prevent wrist pain from writing constantly?
To prevent wrist pain from writing constantly, it is important to maintain good posture while writing and take frequent breaks to stretch and rest your wrists. Using ergonomic writing tools, such as an ergonomic keyboard or pen, can also help prevent strain on the wrists.
3. Is wrist pain from writing constantly a sign of a more serious condition?
In most cases, wrist pain from writing constantly is not a sign of a serious condition. However, if the pain is severe or persistent, it is important to consult a doctor to rule out any underlying conditions such as carpal tunnel syndrome or tendonitis.
4. Can wrist pain from writing constantly be treated at home?
In many cases, wrist pain from writing constantly can be treated at home through rest, ice, and over-the-counter pain medication. It is also important to make sure you are using correct writing techniques and taking breaks to prevent further strain on the wrists.
5. When should I seek medical treatment for wrist pain from writing constantly?
If your wrist pain is severe or persistent, or if you notice any other symptoms such as numbness or tingling in the hands or fingers, it is important to seek medical treatment. Your doctor can provide a proper diagnosis and recommend a treatment plan to help alleviate your wrist pain.
  • General Discussion
10K
14K
10K
