Wrist-watch type human power meters....
In summary, the conversation discussed the idea of measuring human wattage under various conditions, specifically in the context of running up stairs. The participants suggested using wrist-watch type exercise meters or other devices that calculate power based on proxy parameters and algorithms. The conversation also touched on the difficulty of accurately measuring actual wattage and the potential for these devices to assist in physical fitness programs. It was mentioned that humans have a low efficiency when climbing stairs compared to other actions, but still better than thermodynamic efficiency. The conversation ended with a recommendation for a book discussing the idea of quantum processes in the biochemistry of life.
houlahound
908
223
I would like to get a handle on human Wattage under various conditions.
it would be great to compare theory calculations of say running up stairs with how much ACTUAL wattage it takes...just for physics fun.
the only common bench top measurement device I can think of is those wrist-watch type exercise meters.
my guess is they read your pulse and get a heart rate and maybe calculate the mass of blood being pushed around your body and come up with Watts, just a guess?
anyone know how these devices actually calculate power?
As I understand it they don't/can't measure power output directly. They can only measure what they believe to be proxy parameters and apply a proprietary algorithm. I suspect the algorithm they use in a device aimed at runners won't give reliable results for cycling or swimming. The experiment you propose may end up testing how good their algorithm is.
One device I found on the the web is mounted on a belt and measures how fast you are running (strides per min) and impact shock. It didn't say how they turn that into power.
Likes houlahound
Very difficult. The only relevant value is the Work Done On your body by raising it up those stairs. It is possible to meter the total rate of respiration of food over a period. Gas analysis of your lung output can tell you how much CO2 you produce per minute, which will tell you how much glucose your muscles are metabolising. In between is vast unknown territory. Any gizmo that you strap on can only give a rough estimate of what power is going into the muscles that are doing the work. I guess it should be possible to calibrate such a machine against the results of total in against total delivered power. I have no experience of such instruments. Do they give consistent results? That would be one way to see how much you can rely on what they tell you. But many people get a lot of fun from using them. :wink:
Likes houlahound
I guess as long as they are consistent they can be used to assist in a rational physical fitness program for the individual user... too hell if the numbers are kind of fake in the physics sense.
Obesity is becoming a major public health issue in the west so good for the gizmo thingy.
Likes houlahound
"Humans work at only 20% efficiency when climbing stairs and each calorie expended when climbing produces four calories of heat." Not amazingly good but a lot better than thermodynamic efficiency of a heat engine working between those sorts of temperatures. Quantum rules in our cells.
Edit: I just finished reading 'Life on the edge', by Jim Al-Khalili, who's a Theoretical Physicist, author and broadcaster. The book discusses the idea that the biochemistry of life works at the quantum level ("edge") because the processes involved just wouldn't work on a thermodynamic basis. A good, convincing read and it was on offer with Kindle, too! I recommend it.
Likes CWatters
Related to Wrist-watch type human power meters....
1. How does a wrist-watch type human power meter work?
A wrist-watch type human power meter works by using sensors and algorithms to measure the force and speed of the wrist movements while performing physical activities. This data is then converted into power output, which is displayed on the watch.
2. Can a wrist-watch type human power meter accurately measure different types of physical activities?
Yes, a wrist-watch type human power meter can accurately measure various types of physical activities, including running, cycling, and weightlifting. As long as the wrist movements are consistent and within the device's range, it can provide accurate power readings.
3. Is a wrist-watch type human power meter suitable for all fitness levels?
Yes, a wrist-watch type human power meter is suitable for all fitness levels, from beginners to professional athletes. It can provide valuable data and insights for anyone looking to improve their physical performance.
4. Does a wrist-watch type human power meter require any additional equipment?
No, a wrist-watch type human power meter does not require any additional equipment. It is a standalone device that can be worn on the wrist, making it convenient and easy to use.
5. Are there any benefits to using a wrist-watch type human power meter?
Yes, there are several benefits to using a wrist-watch type human power meter. It can help track and monitor physical activity levels, provide accurate data for training and performance improvement, and promote overall fitness and health. It can also serve as a motivational tool for setting and achieving fitness goals.
  • Mechanics
  • Other Physics Topics
11K
