MHB -write expression in expanded form...find the sum
  • Thread starter Thread starter karush
    Expression Sum
The discussion focuses on writing expressions in expanded form and calculating their sums. Participants analyze three specific summations, correcting each other's work and clarifying the calculations. The first summation results in -6, the second totals 40, and the third is identified as an infinite geometric series converging to 10. There is a mention of the difficulty in expanding the third expression and a suggestion for improving LaTeX rendering options for easier use. Overall, the conversation emphasizes collaborative problem-solving in mathematical expressions.
karush
MHB
nmh{2000} index{expanded form}
write each expression in expanded form and then find the sum
\begin{array}{l}
{{9}{\mathrm{)}}\hspace{0.33em}\hspace{0.33em}\hspace{0.33em}\mathop{\sum}\limits_{{n}\mathrm{{=}}{3}}\limits^{5}{\mathrm{(}{n}^{2}}\mathrm{{-}}{2}^{n}{\mathrm{)}}}=(3^2-2^3)+(4^2-2^4)+(5^2-2^5)=-6
\\{{\mathrm{10}}{\mathrm{)}}\hspace{0.33em}\hspace{0.33em}\mathop{\sum}\limits_{{t}\mathrm{{=}}{1}}\limits^{5}{{t}{\mathrm{(}}{t}\mathrm{{-}}{1}{\mathrm{)}}}}
=1(1-1)+2(2-1)+3(3-1)+5(5-1)=40
\\{{\mathrm{11}}{\mathrm{)}}\hspace{0.33em}\hspace{0.33em}\mathop{\sum}\limits_{{i}\mathrm{{=}}{1}}\limits^{\mathrm{\infty}}{\mathrm{10}{\mathrm{\left({\frac{1}{2}}\right)}}^{i}}}
+10\left(\frac{1}{2}\right)^1
+10\left(\frac{1}{2}\right))^2
+10\left(\frac{1}{2}\right)^3
...=10\left(\frac{1}{2}\right)^i=10
\end{array}
hoped answers ok
no sure how to expand 11)
Mathematics news on Phys.org
9. Correct.
10. You omitted the 4(4 - 1) term, otherwise correct.
11. It's an infinite geometric series that converges to a constant. Given that
$$\sum_{n=1}^{\infty}\left(\dfrac12\right)^{1/2}=\dfrac12\lim_{n\to\infty}\dfrac{1-r^n}{1-r}$$
with $r=\dfrac12$, can you compute the result?
Edit: Didn't see the '10' on the right. Ah well, no harm done. As for an expansion, what you have is sufficient I think, just omit the $10\left(\dfrac12\right)^i$ between the expansion and the '10'. ;)
Okay gotit
Don't find these easy😩😩😩
Mahalo
BTW I tried math magic but wasn't worth it
However be nice to have the option
to render latex into an image if we want to use it someplace else
Cropping it out of post with gray background is painful
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
