Write expressions for simple harmonic motion
In summary: But as for the phase shift, how do you know when to use a cosine or sine function when given a particular phase angle? In general, when given a phase shift of φ, you can use either a cosine or sine function. The only difference is that the peaks of the cosine occur at the phase angle φ, while the peaks of the sine occur at the phase angle φ + π/2. So you can choose whichever function you like, just make sure to adjust the phase angle accordingly.
RedBarchetta
50
Write expressions for simple harmonic motion (a) with amplitude 10 cm, frequency 5.0 Hz, and maximum displacement at t=0; and (b) with amplitude 2.5 cm, angular frequency 5.0 1/s, and maximum velocity at t=0.
[tex]
\begin{gathered}
x(t) = A\cos (\omega t + \varphi ) \hfill \\
\omega = 2\pi f \hfill \\
f = \frac{1}
{T} \hfill \\
\end{gathered}
[/tex]
(a)
A=10 cm
f=5.0 Hz
Since the amplitude equals the max displacement at a given t(in this instance t=0), this tells us that the phase angle is zero. So our equation should be...?
[tex]
x(t) = (10cm)\cos \left[ {(10\pi s^{ - 1} )t} \right]
[/tex]
(b)
A=2.5 cm
w=5.0 s^-1
[tex]
\begin{gathered}
V(x) = - A\omega \sin (\omega t + \varphi ) \hfill \\
V(0) = A\omega = V_{\max } \hfill \\
V(0) = - A\omega \sin (\varphi ) \hfill \\
A\omega = - A\omega \sin (\varphi ) \hfill \\
- 1 = \sin (\varphi ) \hfill \\
\varphi = \tfrac{{3\pi }}
{2} \hfill \\
\end{gathered}
[/tex]
So...?
[tex]
x(t) = (2.5cm)\cos \left[ {(5.0s^{ - 1} )t + \tfrac{{3\pi }}
{2}} \right]
[/tex]
Do these look right? Here is what my answer book gives:
[tex]
\begin{gathered}
(a):x(t) = (10cm)\cos \left[ {(\pi s^{ - 1} )t} \right] \hfill \\
(b):x(t) = (2.5cm)\sin \left[ {(5s^{ - 1} )t} \right] \hfill \\
\end{gathered}
[/tex]
Any help is appreciated, thank you.
At a glance, your part (a) should be right considering the frequency given. Your part (b) is equivalent to the answer they state.
A phase shift corresponds to a shift in where the peaks occur. You can consider then, that the phase shift can shift a cosine into a sine or a sine into a cosine. In this sense,
[tex]
cos(x + \frac{3\pi}{2}) = sin (x)
[/tex]
[tex]
[/tex]
Thanks Coto. I had a feeling that the part a solution key was incorrect.
FAQ: Write expressions for simple harmonic motion
What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object moves back and forth in a straight line with a constant frequency and amplitude. This type of motion is often seen in systems like a mass attached to a spring or a pendulum.
What is the equation for simple harmonic motion?
The equation for simple harmonic motion is x = A*sin(ωt + φ), where x is the displacement of the object, A is the amplitude, ω is the angular frequency, and φ is the phase angle.
How is simple harmonic motion different from other types of motion?
Simple harmonic motion is different from other types of motion because it follows a specific pattern of movement that is determined by a restoring force, such as gravity or a spring. This results in a sinusoidal motion that repeats itself over time.
What factors affect the period of simple harmonic motion?
The period of simple harmonic motion is affected by three main factors: the mass of the object, the spring constant of the system, and the amplitude of the motion. As these factors change, the period also changes, with a larger mass or spring constant resulting in a longer period, and a larger amplitude resulting in a shorter period.
How is simple harmonic motion used in real-life applications?
Simple harmonic motion has many real-life applications, such as in clocks, musical instruments, and even seismology. It is also used in the design of suspension systems for vehicles and in the movement of satellites in orbit around the Earth.
