Write out the following set by listing their elements....
In summary: They also say that {3, 4} is a proper subset of B, but is not an element of B.)I'm not sure why I've been laboring under this misconception. Certainly, if A = {2, 4, 6}, then {2, 4} ∈ A.In summary, a set cannot have repeated elements and the cardinality of a set refers to the number of elements in the set. The empty set is a subset of every set, but it is not considered an element of a set. Therefore, the answer to the given question is simply ∅ as there are no sets that have three elements whose cardinality is four.
Rijad Hadzic
321
Write out the following set by listing its elements between braces:
{X : X ⊆ {3,2,a} and |X| = 4}
My book tells me that it is ∅, but couldn't X have repeated elements? so X = {3,2,a,3}, {3,2,a,2} etc for example??
Maybe start out by writing in words what your interpretation of:
... is actually asking.
The set X such that X is a subset of set {3,2,a}, and X has carnality (size) of 4 elements
Ok... walk through it. So you know:
1) X is a subset of the given set.
2.) The given set displays 3 elements.
3.) X itself has a size of 4 elements.
- [Then what's missing, and what are the rules for subsets?]​
That's why I'm asking.. can elements be repeated? Would X be able to have... say... the element a, repeating? Wouldn't ∅ have to be in the set {3,2,a} forthe answer to be ∅?
No: elements of a set cannot be repeated. Other types of collections can have repeated elements, but not sets.
No, they can't be repeated.
Also, the empty set is a subset of every set, but it isn't an element of a set.
Your set, {3, 2, a} contains three elements.
One other thing -- the cardinality of a set is the number of elements in it, Carnality means something entirely different.
Likes SunThief and StoneTemplePython
Not trying to be coy... just trying to be methodical. You can do a wiki search on "Subset" to verify, but my understanding is that:
- ∅ is a subset of every set.
- repeats aren't allowed.​
Okay thanks for clarifying everyone. That's where my main confusion came from: can sets have repeated elements or not.
So the answer to:
isn't simply ∅ like my book says, but instead its {3,2,a,∅}, am I right?
For some reason spell check doesn't acknowledge that cardinality is a word :s I guess it changed it to carnality on accident.
So the answer to:
No. |X| = 3. There are no sets that have three elements whose cardinality (|X|) is 4. The empty set ∅ is a subset of every set, but it's not an element of a set. In symbols, ∀ A, ∅ ⊂ A, but ∅ ∉ A.
Likes SunThief
It has been eons since I actually took a set theory course, but isn't that statement technically false? What about when ##A = \{ \phi \} ##? Isn't ##\phi## both an element and a subset of ##A##?
It's been eons for me as well, so I'm not dead certain what I wrote is correct. My thinking is that there's a distinction between subsets of a set vs. elements of a set. For example, if A = {2, 4, 6}, then {2, 4} ⊂ A, but we wouldn't write {2, 4} ∈ A.
Further, the cardinality of my set A, or |A| is 3, whilie |∅| is 0. If ∅ were an element of A, wouldn't A's cardinality be 4? (Which gets us back to the question of the OP.)
As a sideline, it turns out that the reason we use ∈ (a stylized ##\epsilon##) is that epsilon is the first letter of the Greek word ἐστί, "is." Transliterated, this would be something like "esti".
I wasn't referring to the particular A in the OP. Rather, to the dummy variable A in your statement "In symbols, ∀ A, ∅ ⊂ A, but ∅ ∉ A." It seems to me that ##A = \{ \phi \} ## is a counterexample to that statement.
I concede your point. I've been laboring under the misconception that a subset of a set wasn't also considered an element of the set. After searching a number of wiki pages, I found one that says that a subset of a set is also considered an element of the set -- https://en.wikipedia.org/wiki/Element_(mathematics). An example they give is B = {1, 2, {3, 4}}, which they describe as having three elements: 1, 2 and {3, 4}.
Related to Write out the following set by listing their elements....
1. What does it mean to "write out a set by listing its elements?"
When writing out a set, you are essentially creating a list of all the distinct objects or numbers within that set. This means that you are identifying and listing each individual element of the set.
2. How do I write out a set?
To write out a set, you can use curly braces { } to enclose the elements of the set, separated by commas. For example, if the set is "even numbers between 1 and 10", you would write it as {2, 4, 6, 8, 10}.
3. Can a set have repeating elements?
No, a set cannot have repeating elements. Each element in a set must be unique and cannot be repeated. For example, {1, 2, 2, 3} is not a valid set because the number 2 is repeated.
4. What is the difference between a set and a list?
A set is a collection of distinct elements, meaning each element is unique and cannot be repeated. A list, on the other hand, can have repeating elements and the order of the elements is important. Additionally, sets are denoted by curly braces { }, while lists are denoted by square brackets [ ].
5. Are sets and subsets the same thing?
No, sets and subsets are not the same thing. A subset is a set that contains elements that are all part of a larger set. For example, {2, 4, 6} is a subset of {1, 2, 3, 4, 5, 6}. However, a subset can also contain all the elements of the larger set, making it equal to the larger set.
  • Linear and Abstract Algebra
