Write the kinetic energy of the sphere
In summary: Right?In summary, the conversation discusses the correct method for calculating the kinetic energy of a sphere attached to a string and released from a fixed point. The first method, using the parallel axis theorem, is deemed correct because the string is not significantly longer than the radius of the sphere. The second method, treating the sphere as a point mass, is not accurate enough because the string equals the radius and different parts of the sphere are moving at different speeds. The conversation also touches on the fact that the centre of mass is not the same as the centre of moment of inertia, which can affect the calculation. Replacing the string with a stiff rod can also change the dynamics of the system.
ritwik06
580
I have a string(length= r) and negligible mass to which a uniform sphere of radius r is attached on one end. I fix upper end of the string to the ceiling and release the sphere when it made angle θ0 with the vertical. I have to write the kinetic energy of the sphere when it makes an angle θ with the vertical.
Say, the angular velocity of the center of mass about the point of suspension be ω when it makes an angle θ.
I have a doubt:
Way 1:
KE=0.5*Iω2
Using parallel axis theorem;
'I' about the point of suspension= (2/5)mr2+m(2r)2
=4.4mr2
KE=2.2mr2ω2
Way 2:
KE=0.5*mvcm2
v=2rω
KE=2mr2ω2
Which of these is correct. My book gives the method 1 as a correct solution. But I cannot understand what's wrong with method 2?
What I think is that method 1 gives kinetic energy when the sphere itself is rotating about its own axis with the same angular velocity 'ω' as the center of mass has about the point of suspension. Am I right?
But in the case specified does the sphere rotate about its axis? If yes, from where does the torque come from? The tension and the mass both pass from the center of mass, so they will have zero torque.
Please help me. I am confused!
ritwik06 said:
Way 2:
KE=0.5*mvcm2
v=2rω
KE=2mr2ω2
Hi Ritwik! :smile:
Method 2 is the one we usually use for a sphere, because we usually treat the sphere as a point mass (so that the whole mass moves with the same speed, rω).
When the string is a lot longer than the radius of the sphere, that's accurate enough.
But here, the string equals the radius, and the approximation isn't good enough …
different parts of the sphere are moving with different speeds, and the average speed isn't:wink:
so we can't treat the sphere as a point mass, and we have to do it "properly". :smile:
Further complication:
Since the sphere has angular acceleration, the string is not
in line with the centre of the sphere.
To make it agree with the expected answer, the string should
be replaced by a light stiff rod rigidly attached to the sphere.
The original problem is close to an example of chaos theory!
Although I would see it as an example of 2 "normal modes" of
oscillation. The 2 variables are the angles of rotation of the sphere,
and the angle of the string. In one normal mode these are in phase,
and in the other antiphase.
David
tiny-tim said:
Hi Ritwik! :smile:
I understood that exactly! the sphere will also rotate about its center, right? But from where did the torque to cause this roatation came from?
That was exactly the point I was making.
In fact the sphere's angle of rotation about its centre is slightly greater
than the string's angle. This enables the string to provide the torque required.
David
David
First please tell me, the angular velocity about the sphere about its axis should be equal to the angular velocity of the center of mass about the suspension point for method 1 to be correct, right?
That means the there is rotation in the sphere about its center of mass! Now to cause this rotation, there must be a torque on the body. From where did this torque come from?
No!
This has nothing to do with rotation!
(and there's no torque!)
The bits of the sphere at height h above the centre are moving at speed (r+h)ω,
so the moment of inertia of those bits has a factor of (r+h)2ω, and the average of that is not r2ω … the lower bits have more contribution than the upper bits …
to put it another way, the centre of mass is not at the same place as the centre of moment of inertia.
David
Oh thanks! I understood. And if I replace the string with a stiff rod, will there be any rotation about the center? Then I presume method two will work there. Right?
tiny-tim said:
No!
I see through that, but the thing is that it can be possible only when the sphere rotates. I don't wish to be rude, I just want to clarify my concepts.
Please see through my viewpoint: suppose the sphere does not undergo rotation about its centre. Then can I say that all the particles on the sphere will have the same velocity as the centre of mass? Without rotation about its own axis, is there any other way that the velocities of the particles in/on the sphere are different? I don't think so.
No. You still need to take into account the sphere's rotation about its
centre of mass. But now the "rigid" connection between rod and sphere
ensures that they have the same angular velocity, and the rigid connection
provides the necessary torque, which string can't do.
ritwik06 said:
… suppose the sphere does not undergo rotation about its centre. Then can I say that all the particles on the sphere will have the same velocity as the centre of mass? Without rotation about its own axis, is there any other way that the velocities of the particles in/on the sphere are different? I don't think so.
The sphere is rotating about the top of the string.
That is why the moment of inertia needs to be calculated relative to an axis through the top of the string. :wink:
Each point on the sphere is moving in an arc whose centre is the top of the string.
That is all you need for Way 1 in the book. :smile:
Thanks a lot. I get it now.
Thank you! I see through it! Can you find a practical example where all the points on the sphere do have the same velocity?
Will this do? -----> Say a rigid rod is attached to the center of the sphere and the attachment is such that the sphere does not rotate about it centre. Now will the way 1 be applicable?
tiny-tim said:
No!
Yes. Cut the sphere almost in two so that it is like a yoyo,
and attach the string at its centre.
I get it completely now, i think a rod will be better than a string to avoid rotations about the centre?
A string might still allow rotation about the center. What do you say?
I am sorry. A string would work too if attached to the centre as even if there are forces there on centre of mass their net torque woul be zero. Am I right?
Thanks a lot!
It might "allow" it, but with the only forces on the sphere now being
gravity and tension applied to the centre, there is now nothing to cause it.
The sphere could be spinning with constant angular velocity, (string loop
round the axle slips rather than winds up) but the sphere still moves as if
it were a point mass at its centre.
Thanks a lot!
exactly
OTOH a rod welded to the axle would constrain the sphere to
rotate with it, and such a joint can transmit the required torque.
davieddy said:
exactly
Thank you very very much!
Enjoyed. There's a simple principle I still want to explain (PM me or I will you)
Meantime enjoy this one.
Love,
David
davieddy said:
Since the sphere has angular acceleration, the string is not in line with the centre of the sphere.
i] there is no reason why the string should not stay in line with the centre of the sphere, so long as the sphere was released carefully enough
ii] the answer in the book makes it very clear that that is the correct interpretation of the question
… I would see it as an example of 2 "normal modes" of
oscillation. The 2 variables are the angles of rotation of the sphere, and the angle of the string. In one normal mode these are in phase, and in the other antiphase.
and iii] yes, that's absolutely correct …
if you don't release the sphere carefully at the start, it will have an "extra" rotation (in addition to the rotation about the top of the string) …
but this is a wholly different, more advanced, topic (probably involving Lagrangians) which I assume is not on this part of Ritwik's syllabus :wink:
Ritwik, to pass your exams, you must be able to understand why the way given in your book works! :smile:
Both Ritwik and I have explained that while we, you or the textbook author might
be capable of visualizing the string/sphere system as a rigid body, it ain't.
The sphere has rotational acceleration, and this requires some moment about its c of m.
The important point to stress is that the kinetic energy and angular momentum
of any set of particles is that of the total mass located at the c of m PLUS that
relative to the c of m. The same applies to linear momentum, but more or less by
definition, the linear momentum relative to the c of m is zero.
admittedly, but since the problem focuses attention on the rotation of the sphere
(as you pointed out in your first post) it is relevant.
I have every confidence in him/her!
David
I have a doubt:
Way 1:
KE=0.5*Iω2
=4.4mr2
KE=2.2mr2ω2
Way 2:
KE=0.5*mvcm2
v=2rω
KE=2mr2ω2
I think all of us are guilty of ignoring the first rule of passing exams:
READ THE QUESTION.
If we were told that a mass m was released from rest at height h0,
and were asked for its kinetic energy when it had reached height h, we wouldn't
expect many marks for the answer "1/2mv^2".
[Or even 1/2(mv^2 + Iω^2)]
Ritwik, could you give us the full question as posed?
FAQ: Write the kinetic energy of the sphere
What is kinetic energy?
Kinetic energy is the energy that an object possesses due to its motion. It is defined as the energy an object has because of its motion, and is dependent on the mass and velocity of the object.
How is kinetic energy calculated?
Kinetic energy is calculated using the equation KE = 1/2 * m * v^2, where KE represents kinetic energy, m represents the mass of the object, and v represents the velocity of the object.
Why is kinetic energy important?
Kinetic energy is important because it is a fundamental concept in physics and is used to describe the motion of objects. It is also important in various real-world applications, such as in transportation and energy production.
How is kinetic energy related to potential energy?
Kinetic energy and potential energy are both forms of energy. Kinetic energy is the energy of motion, while potential energy is the energy an object has due to its position or condition. The two forms of energy can be converted into each other, such as when an object falls and its potential energy is converted into kinetic energy.
How does the mass and velocity of an object affect its kinetic energy?
The kinetic energy of an object is directly proportional to its mass and velocity. This means that as the mass or velocity of an object increases, so does its kinetic energy. For example, a heavier object moving at a faster speed will have a greater kinetic energy than a lighter object moving at a slower speed.
