Write the Maclaurin series for (1+x)^(-1/2) as a sum
In summary, the Maclaurin series for (1+x)^(-1/2) is a mathematical representation of the function's values at various points near its origin. It is derived by taking the Taylor series expansion of (1+x)^(-1/2) and simplifying it to a sum of increasing powers of x. This series is useful for approximating the values of the function and can be used in various calculations involving (1+x)^(-1/2).
Potatochip911
318
Write the Maclaurin series for ##\frac{1}{(1+x)^{1/2}} ## in ##\sum## form using the binomial coefficient notation. Then find a formula for the binomial coefficients in terms of n.
3. The Attempt at a Solution [/B]
$$\frac{1}{(1+x)^{1/2}}=1-\frac{x}{2}+\frac{3x^2}{8}-\frac{5x^3}{16}+\frac{35x^4}{128} $$
This is where I get stuck, I can't seem to figure out the formula for how the terms are increasing. Is there a way to figure out the formula without using a guess and check method?
Do you know how to find a Maclaurin series in general ?
As in ##(1+x)^p=1+\frac{p\cdot x}{1!}+\frac{p(p-1)\cdot x^2}{2!}+...##?
I was thinking more general, but that's perfectly adequate here and a good place to start.
Of course p = -1/2 in your case.
Yea I have derived quite a few Maclaurin series for practice but I am having trouble rewriting the terms as a power series. I think it looks something like this ##\sum_{n=0}^{\infty} \frac{x^n}{2^n}## but I'm struggling to find the rest
Write out a few terms.
Write out the general term with xn in it.
Look for patterns.
Likes Potatochip911
Look for patterns.
$$(1+x)^p=1+\frac{p}{1!}x+\frac{p(p-1)}{2!}x^2+\frac{p(p-1)(p-2)}{3!}x^3+\frac{p(p-1)(p-2)(p-3)}{4!}x^4 \\
(1+x)^{-1/2}=1+\frac{(\frac{-1}{2})}{1!}x +\frac{(\frac{-1}{2})(\frac{-3}{2})}{2!}x^2+\frac{(\frac{-1}{2})(\frac{-3}{2})(\frac{-5}{2})}{3!}x^3\\
(1+x)^{-1/2}=1+\frac{-1}{2*1!}x+\frac{(-1)(-3)}{2*2*2!}x^2+\frac{(-1)(-3)(-5)}{2*2*2*3!}x^3 \\
(1+x)^{-1/2}=1+\frac{(-1)(1)}{2*1!}x+\frac{(-1)^2(1)(3)}{2*2*2!}x^2+\frac{(-1)^3(1)(3)(5)}{2*2*2*3!}x^3 $$ So I think the formula is ## \sum_{0}^{\infty} \frac{(-1)^n(2n-1)!}{2^n\cdot n!} x^n## My only concern is that when n=0 (2n-1)! goes to (-1)!.
(1+x)^{-1/2}=1+\frac{(-1)(1)}{2*1!}x+\frac{(-1)^2(1)(3)}{2*2*2!}x^2+\frac{(-1)^3(1)(3)(5)}{2*2*2*3!}x^3 $$ So I think the formula is ## \sum_{n=0}^{\infty} \frac{(-1)^n(2n-1)!}{2^n\cdot n!} x^n## My only concern is that when n=0 (2n-1)! goes to (-1)!.
Oh, you mean (-1)! .
Believe it or not, (-1)! is defined & is equal to 1.
Similar to the way you can get ##\ 0!=1\,,\ ## the recursion relation for double factorial is ##\displaystyle \ n! = n\cdot(n-2)! \,,\ ## which gives you the result if n = 1 .
Alternatively, ##\displaystyle \ (2n-1)! = \frac{(2n)!}{2^n(n!)}\ .##
See http://en.wikipedia.org/wiki/Double_factorial .
Likes HallsofIvy and Potatochip911
Related to Write the Maclaurin series for (1+x)^(-1/2) as a sum
1. What is a Maclaurin series?
A Maclaurin series is a type of power series that represents a function as an infinite sum of terms. It is named after Scottish mathematician Colin Maclaurin and is a special case of a Taylor series, where the expansion point is x=0.
2. How do you find the Maclaurin series for (1+x)^(-1/2)?
To find the Maclaurin series for (1+x)^(-1/2), we can use the binomial series expansion formula: (1+x)^n = 1 + nx + n(n-1)x^2/2! + n(n-1)(n-2)x^3/3! + ... + n(n-1)(n-2)...(n-k+1)x^k/k! + ... where n = -1/2. This gives us the series: 1 - (1/2)x + (3/8)x^2 - (5/16)x^3 + (35/128)x^4 - ...
3. What is the significance of the Maclaurin series for (1+x)^(-1/2)?
The Maclaurin series for (1+x)^(-1/2) is significant because it is the series expansion for the function 1/sqrt(1+x), which is a commonly used function in calculus and physics. It allows us to approximate the value of the function for any value of x, which can be useful in solving complex mathematical problems.
4. How many terms should I use in the Maclaurin series for (1+x)^(-1/2) to get an accurate approximation?
The more terms we use in the Maclaurin series for (1+x)^(-1/2), the more accurate our approximation will be. However, it is often sufficient to use just a few terms to get a good approximation. For example, using the first 5 terms of the series (1 - (1/2)x + (3/8)x^2 - (5/16)x^3 + (35/128)x^4), we can get an approximation for (1+x)^(-1/2) that is accurate up to the 4th decimal place for values of x between -1 and 1.
5. Can the Maclaurin series for (1+x)^(-1/2) be used to find the value of the function at x=2?
Yes, the Maclaurin series for (1+x)^(-1/2) can be used to find the value of the function at any value of x, including x=2. We just need to substitute x=2 into the series and add up the terms to get the approximation for (1+2)^(-1/2) or 1/3, which is the value of the function at x=2.
