Write the tangent lines to the curve
In summary, to find the equations of tangent lines to the curve of the implicit function x^2+2x+2y^2-4y=5 that are normal to the line y=x+12, you need to set the derivative equal to -1 and solve for y in terms of x. Then, you can replace y in the original function equation and solve for x to find the points.
Jpyhsics
84
Write the equations of tangent lines to the curve of the implicit function x2+2x+2y2-4y=5
that are normal to the line y=x+122. The attempt at a solution
I know that the slope has to be m=-1
I found the derivative using implicit differentiation:
dy/dx=(-2x-2)/(4y-4)
Now I am unsure how to find the points, please help it is due tomorrow.
The derivative must equal -1. That should give you an equation that you can solve for y in terms of x. You can replace y in your original function equation and solve it for x.
Related to Write the tangent lines to the curve
1. What is the definition of a tangent line?
A tangent line is a line that touches a curve at only one point and has the same slope as the curve at that point. It can be thought of as the instantaneous direction of the curve at that specific point.
2. How do you find the equation of a tangent line to a curve?
To find the equation of a tangent line to a curve, you need to first find the slope of the curve at the point of tangency. This can be done by taking the derivative of the curve at that point. Then, using the point-slope formula, plug in the point of tangency and the slope to find the equation of the tangent line.
3. Can a curve have more than one tangent line at a given point?
No, a curve can only have one tangent line at a given point. This is because the tangent line represents the instantaneous direction of the curve at that point, and if there were more than one, the curve would not have a unique direction at that point.
4. What is the relationship between the slope of the tangent line and the derivative of the curve?
The slope of the tangent line at a point is equal to the value of the derivative of the curve at that same point. This is because the derivative represents the rate of change of the curve, and the slope of the tangent line represents the instantaneous change of the curve at that point.
5. How do you know if a line is tangent to a curve or just intersects it?
A line is tangent to a curve if it only intersects the curve at one point and has the same slope as the curve at that point. If a line intersects the curve at more than one point, it is not a tangent line.
