Writing a double integral from a graph
i.e. changing depending on the upper limit of the outer integral, just makes it a little more complicated to do the integration.
arl146
343
A region R is given. (ill just tell you that it is a triangle, given by lines x = -2, y = 2, and y = x).
Decide whether to use polar coordinates or rectangular coordinates and write [itex]\int[/itex][itex]\int f(x,y)dA[/itex] as an iterated intergal, where f is an arbitrary continuous function.
so, i already know to use polar coordinates. i have the answer for the problem which is :
[itex]\int[/itex][itex]\int f(x,y)dydx[/itex] where the x's boundaries are -2 to 2 and the y's boundaries are x to 2.
i understand why the lower x boundary is -2, and why the upper y is 2. but why is the x upper 2 and the y lower x? why can't it be like the x boundaries are -2 to y and the y boundaries are x to 2 ?
The region R is expressed in the limits of integration in this integral.
[tex]\int_{x = -2}^2\int_{y = x}^2 f(x, y)~dy~dx[/tex]
The inner integration takes place in a thin vertical strip of width dx, that runs from the line y = x to the horizontal line y = 2. Every vertical strip is exactly the same in this regard. The integration adds up the rectangles from bottom to top, where each rectangle has an area of dx*dy.
The outer integration takes place by adding up the vertical strips of the inner integration, in essesnce sweeping from left to right. The strips run from x = -2 on the left to x = 2 on the right.
I think you mean that you know to use rectangular coordinates (since that's what you used, and I think polar would be inadvisable here anyway). As to your question, you do have a choice in the matter. Suppose we fix some value of y (see the green strip in picture below). Then for that y, x would be integrated from -2 to the x value corresponding to where that fixed y touches the other boundary (in this case, it's the line y = x), which in this case is at the point x = y. So you're integrating x from -2 to y first. Then you want to integrate over all relevant values of y, which would be from the bottom of the triangle (y = -2) to the top (y = 2). Thus the integral is
[tex]\int_{-2}^2\ \int_{-2}^y\ f(x,y)\ dx\ dy[/tex]
Note that the order of the differentials is important here, since you have to integrate with respect to x first.
Alternatively, you could integrate with respect to y first. Here you would pick some fixed value of x (see the yellow strip in the picture). Then you would integrate y from the y-coordinate corresponding to wherever that x touched the bottom boundary (in this case, y = x) to the top (y=2). Then you would integrate over all relevant values of x. In this case, the integral becomes
[tex]\int_{-2}^2\ \int_x^2\ f(x,y)\ dy\ dx[/tex]
In practice, which you choose depends upon the function itself. Since you're looking at an arbitrary function, just choose one.
http://img844.imageshack.us/img844/6977/changeofvars.png
ok i get the 'inner integration' but i still don't get the outer one .. yea, youre going from x=-2 but it still hits the line y=x there is no line that's x=2.. i don't get that one
i don't get it, your green line still hits y=x -____-
Where do the vertical strips run from and to in the outer integral? From x = -2 on the left to x = 2 on the right.
ok i guess i see it but then why don't you look at the outer integration in the same way as the inner... like why do you say, oh the vertical strips from the inner integration run from x=-2 to x=2.. why can't it be independent of the inner integration strips
Because in the inner integration, the strips are different lengths. In the outer integration you're just adding all the strips going from left to right. Having the lower limit of integration being a variable for the inner integral takes into account that the strips are different lengths.
ok! thanks
The green line would be a horizontal strip if the integration happened in the opposite order.
In that case the inner integral would look at horizontal strips (like the green line), that run from x = -2 to x = y. The outer integral would essentially add all the horizontal strips, from y = -2 to y = 2. The integral would look like the first one in post #3.
[tex]\int_{y = -2}^2\ \int_{x = -2}^y\ f(x,y)\ dx\ dy
[/tex]
Related to Writing a double integral from a graph
1. How do I identify the limits of integration for a double integral from a graph?
In order to identify the limits of integration for a double integral from a graph, you will need to look at the boundaries of the shaded region on the graph. These boundaries will correspond to the limits of integration for the inner and outer integrals.
2. How do I determine the order of integration for a double integral from a graph?
The order of integration for a double integral is determined by the shape of the region and the order in which the variables are integrated. If the region is rectangular, the order of integration is typically dx dy. If the region is triangular, the order of integration can be either dx dy or dy dx, depending on the orientation of the triangle.
3. What is the purpose of using a double integral to represent a region on a graph?
A double integral allows us to calculate the volume under a surface that is defined by a function on a two-dimensional region. It is a useful tool in many areas of science, including physics, engineering, and economics.
4. Can a double integral be used to calculate other quantities besides volume?
Yes, a double integral can be used to calculate other quantities such as area, mass, and average value. It can also be used to solve various types of optimization problems.
5. Are there any shortcuts or tricks for writing a double integral from a graph?
There are some shortcuts and tricks that can be used to simplify the process of writing a double integral from a graph. These include using symmetry to reduce the number of integrals, using substitution to change the variables, and breaking the region into smaller, easier-to-integrate parts.
