Writing a function of x and y as a function of z
In summary, there is no general method for converting a complex function into a function of just z. However, one possible method is to use the equations x=(z+z^)/2 and y=(z-z^)/2i, but this may not always work if the function is not analytic in the complex plane.
ericm1234
73
Is there a general method for this?
I remember in complex analysis going the other direction; that is, a function of z becoming a function of x and y.
But I need to turn a complex function in a function of just z, for the purpose of integrating with respect to z.
In particular, the function is
x^2/2-cx-y^2/2+ i(x-c)y where c is a constant.
When you say z, are you referring to z, as in the third coordinate of an x,y,z system or the complex variable z, as in z= x + iy?
complex variable z, as in z=x+iy.
In fact I now see how to write this in terms of z but it is from recognizing the form. Is there a more general method?
Please no one reply with "well if you recognize the form in this particular equation.", because again, I already see it.
General method please?
Hi, try:
x= (z+ z^)/2 , where z^ is the conjugate, i.e. if z=x+iy, then z^= x-iy
y=( z- z^)/2i
It comes from z=x+iy
Thanks
Be aware that you cannot necessarily write a function f(x,y) solely as a function of ##z = x + i y##. You may find that the complex conjugate ##z^\ast = x - iy## does not cancel out of your expression.
You will only be left with a function of z (and not z*) if your function is analytic in the complex plane.
FAQ: Writing a function of x and y as a function of z
How do you write a function of x and y as a function of z?
To write a function of x and y as a function of z, you need to first determine the relationship between x, y, and z. This relationship will then be expressed using mathematical operations and variables to create an equation that represents the function.
What is the purpose of writing a function of x and y as a function of z?
The purpose of writing a function of x and y as a function of z is to show the dependence of x and y on the independent variable, z. This allows for easier analysis and manipulation of the data, and can be useful in solving various mathematical and scientific problems.
How do you determine the domain and range of a function of x and y as a function of z?
The domain of a function of x and y as a function of z is the set of all possible values of z for which the function is defined. The range is the set of all possible values of the dependent variable, y, that result from the function for a given range of z values. To determine the domain and range, you can analyze the equation of the function and consider any restrictions or limitations on the variables.
Can a function of x and y as a function of z have multiple solutions?
Yes, a function of x and y as a function of z can have multiple solutions. This means that for a given value of z, there can be more than one possible value for x and y that satisfy the equation. This is common in complex equations and can result in a variety of solutions depending on the given values of z.
How can you graph a function of x and y as a function of z?
To graph a function of x and y as a function of z, you can use a 3D graphing tool or plot multiple 2D graphs for different values of z. This will allow you to visualize the relationship between x, y, and z and see how changes in z affect the values of x and y. It is important to note any restrictions or limitations on the variables when graphing the function.
