Saitama
- 4,243
- 93
Here's the problem statement from HackerRank: https://www.hackerrank.com/contests/programaniacs-june-15/challenges/sum-of-squares-1
Since the constraints are small, I tried a DP solution. Code I have written so far:
dp[j] denotes the number of ways to write $i$ as sum of $j$ squares.
The problem with the above code that it overcounts the number of ways. How do I fix this issue?
Thanks!
Problem Statement
Find the number of n-tuples $(a_1,a_2,a_3,\cdots, a_n)$ such that
$$a_1^2+a^2_{2}+a^2_{3}+\cdots+a^2_{n} = k\,\,\,\text{and}\,\,\, a_1≤a_2≤\cdots≤a_n\,\, \text{where} \,\,a_i>0$$
Input Format
The first line contains the number of test cases $T$.
The next $T$ lines contain two integers, $n$ and $k$.
Constraints
$1≤T≤10^5$
$1≤n≤100$
$1≤k≤5000$
Output Format
For each of the $T$ test cases, output one integer, the answer to the problem.
Sample Input
1 4
2 50
3 1000
Sample Output
Code:
#include <cmath>
#include <cstdio>
#include <vector>
#include <iostream>
#include <algorithm>
using namespace std;
typedef long long ll;
ll dp[5010][101]={};
int main() {
ll T, i, j, n, k;
vector<ll> sq;
for(i=1; i*i<=5000; ++i)
sq.push_back(i*i);
for(i=0; i<sq.size(); ++i)
dp[sq[i]][1]=1;
for(i=2; i<=5000; ++i)
for(j=2; j<=min(i, 100LL); ++j)
for(k=0; k<sq.size(); ++k)
if(sq[k]>i)
break;
dp[i][j]=dp[i][j]+dp[i-sq[k]][j-1];
cin>>T;
while(T--)
cin>>n>>k;
cout<<dp[k][n]<<endl;
return 0;
Thanks!
