Writing a squared observable in Dirac notation
In summary, the expectation value of a squared observable in Dirac notation is written as <A^2>=<\psi|\hat A^2|\Psi>=<\psi|\hat A \hat A|\Psi>=<\hat A \psi|\hat A\Psi>, with the operator acting on the right on Psi and the property of Hermitian operators taken into account.
Zero1010
40
I need help writing in Dirac notation
##<A>=\int_{-\infty}^\infty \Psi^*(x) \hat A \Psi (x) dx ##
##<A> = <\Psi|\hat A|\Psi>##
##<A^2>=\int_{-\infty}^\infty |\Psi^*(x)|^2 \hat A^2 dx ##
Edited after post below:
Hi,
I need to show that the square of the expectation value of an observable takes a certain form in Dirac notation.
I know in wave notation that the expectation value is a sandwich integral which looks like this:
Which is written in Dirac notation as:
And the expectation value of a squared observable is written as:
##<A^2>=\int_{-\infty}^\infty \Psi^*(x) \hat A^2 \Psi(x) dx ##
But I am not sure how to write this in Dirac notation.
Thanks for any help and hopefully this makes sense.
This can't be right. You have a number on the LHS and an operator on the RHS. It should be:
##<A^2>=\int_{-\infty}^\infty \Psi^*(x) \hat A^2 \Psi (x) dx ##
Note also that this is the expectation value of the square of the observable/operator and not to be confused with ##\langle A \rangle^2##, which is the square of the expectation value.
Thanks for the heads up.
I was looking at the expectation value from my textbook (see image) which is obviously different. Thanks
If you have the position operator, or the position operator squared, then we have:
##\Psi^*(x) \hat x^2 \Psi(x) = \Psi^*(x) x^2 \Psi(x) = |\Psi(x)|^2x^2##
But, this does not hold for a general operator ##\hat A##. For example, if we have the differential operator:
##\Psi^*(x) \hat D \Psi(x) = \Psi^*(x) \frac{d\Psi}{dx}(x) \ne |\Psi(x)|^2 \frac{d}{dx}##
Likes DEvens
Ok that makes sense.
The operator I am dealing with is Hermitian which is important later in the question I'm working on.
So in Dirac notation is it just written as:
##<\Psi(x)|\hat A^2|\Psi(x)>##
Likes DEvens
Yes, that's the expectation value for the operator ##\hat A^2##. Look at it this way: you could write ##\hat B = \hat A^2##, then:
##\langle A^2 \rangle = \langle B \rangle = \langle \Psi | \hat B |\Psi \rangle = \langle \Psi | \hat A^2 |\Psi \rangle ##
Ok. Thanks for your help so far its been great.
One last thing, does this make sense (hopefully):
##<A^2>=<\psi|\hat A^2|\Psi>##
##<A^2>=<\psi|\hat A \hat A|\Psi>##
The operate on the right acts on Psi so:
##<A^2>=<\psi|\hat A|\hat A\Psi>##
Since ##\hat A## is Hermitian (therefore - ##<f|\hat A g> = <\hat A f| g>##):
##<A^2>=<\hat A \psi|\hat A\Psi>##
Yes. In general:
##\langle \Psi|\hat A \hat B|\Psi \rangle = \langle (\hat A^{\dagger} \Psi)|(\hat B\Psi) \rangle##
Likes DEvens
Cool.
Thanks again for your help.
Related to Writing a squared observable in Dirac notation
1. What is a squared observable?
A squared observable is a mathematical quantity that represents the measurement of a physical property of a system. It is typically represented by a Hermitian operator and its square represents the expectation value of the corresponding physical observable.
2. How is a squared observable written in Dirac notation?
In Dirac notation, a squared observable is written as Ĥ², where Ĥ is the Hermitian operator corresponding to the observable. This notation is commonly used in quantum mechanics to represent physical quantities and their measurements.
3. What is the significance of writing a squared observable in Dirac notation?
Writing a squared observable in Dirac notation allows for a more compact and concise representation of physical quantities and their measurements. It also makes it easier to perform calculations and manipulate mathematical expressions involving observables.
4. How is a squared observable measured in experiments?
In experiments, a squared observable is measured by applying the corresponding Hermitian operator to the system and then measuring the resulting eigenvalue. The square of this eigenvalue represents the measurement of the observable.
5. Can a squared observable have negative values?
No, a squared observable cannot have negative values. This is because it represents the expectation value of a physical quantity, which cannot be negative. However, the eigenvalues of the corresponding Hermitian operator can be negative, but their squares will be positive.
