Writing author notes in REVTeX 4.1 for PRL
In summary, the author would like to include a note in the acknowledgments stating "These authors have contributed equally to this work." He is unable to do this using the standard notation and is looking for help from the Physics Forums community.
jayantshaq
Hello,
I am currently writing a paper for submission to the PRL. I wish to put in a note after the names of the first two authors, stating "These authors have contributed equally to this work". I would like to solicit the help of the Physics Forums community in knowing how to do this. In some previous PRL papers I have seen, this is denoted by an asterisk after the authors' names, the explicatory text to which is then placed just before the references (after the horizontal mark denoting the end of the paper). I have been fiddling around with the REVTeX 4.1 template for a while now, but cannot seem to get this note correctly. I would be grateful for any help.
The closest that I have got so far is by including the note in the \thanks{} field. The only problem with that is that the asterisk seems to be much smaller than is standard for the particular note.
Author bylines are supposed to identify the institutions with which the different authors are associated. The APS appears to frown on superfluous things such as titles, which author did most of the work, etc. The editor (if not the reviewers) will strike a byline along the lines of the one you would like to use. You might be able to put the remark in a final acknowledgments paragraph. Then again, maybe not. The remark is a bit non-professional.
Did all three of you really contribute equally? Be honest. One of you almost certainly contributed more in terms of originality. One of you took the burden of writing the paper. One of you is going to have to take responsibility of shepherding the paper through the review process. If you really can't decide whose name goes first, draw straws and make the person who draws first author work to deserve that honor. There's a whole lot of work left to do on the paper. Presumably the review process hasn't even begun.
If the three of you are going to collaborate further you can use a round-robin approach regarding first author.
Hi D H,
Thanks for your quick and sound reply.
Regarding the question of whether some of the authors really contributed equally, it is difficult to say for certain. Different parts of the work were largely the responsibility of different people, and two of them certainly took on the larger shares. According them equal author status keeps things simple and cordial.
You are right, the remark may well be a bit unprofessional. However, as I mentioned, some PRL papers do contain it, on the basis of which I am reasonably sure that it will pass through the refereeing+editing process unscathed.
The round-robin approach that you suggest is indeed practical, and we may well follow it when the question of credit allocation is even murkier. However, for this paper, I would prefer to include the remark, if possible, and any help in that regard would be highly appreciated.
I understand the importance of properly acknowledging the contributions of all authors in a paper. In order to add author notes in REVTeX 4.1 for PRL, you can use the \author command and include the appropriate note in square brackets after the author's name, as shown in the REVTeX 4.1 template. For example, if the first two authors have contributed equally, you can write their names as \author{First Author$^{1}$, Second Author$^{1}$}, with the note "These authors have contributed equally to this work" written as \author{First Author$^{1}$, Second Author$^{1}$[*]}. This will automatically add the asterisk after their names and the explicatory text will be placed just before the references, as you have observed in previous PRL papers. I hope this helps and good luck with your submission.
FAQ: Writing author notes in REVTeX 4.1 for PRL
1. What is the purpose of including author notes in a REVTeX 4.1 document for PRL?
The purpose of including author notes in a REVTeX 4.1 document for PRL is to provide additional information or acknowledgments that may not fit within the main body of the paper. This can include funding sources, previous related work, or other relevant details.
2. How do I format author notes in REVTeX 4.1 for PRL?
To format author notes in REVTeX 4.1, use the \author command followed by the author's name and an optional \thanks command for the note. Multiple authors can be listed by separating them with commas. Author notes should be placed before the \maketitle command.
3. Can I include equations or references in my author notes?
Yes, equations and references can be included in author notes using the appropriate REVTeX commands. However, it is recommended to keep author notes concise and avoid excess equations or references.
4. How do I customize the appearance of my author notes in REVTeX 4.1 for PRL?
To customize the appearance of author notes, use the \author command with the optional arguments affiliation, email, or altaffiliation. These can be used to specify the author's affiliation, email address, or multiple affiliations, respectively. Additionally, the \thanks command can be used to add a footnote symbol to the author's name.
5. Are there any restrictions on the content of author notes in REVTeX 4.1 for PRL?
While there are no specific restrictions on the content of author notes, it is important to ensure that they are relevant and appropriate for the paper. Additionally, make sure to follow any guidelines or requirements set by the journal or publication.
