Writing decimal radians in terms of Pi
In summary, the conversation is about converting radians to decimal form in terms of Pi. The person asking the question is curious about this conversion and wants to know if there is a way to do it without using degrees. The conversation also touches on why it may not be necessary to convert to Pi and how some fractions can be written in terms of Pi.
Matty R
83
Hello :smile:
Sorry if this is in the wrong place, I don't know where else to put it.
Is there a way to write radians as decimals in terms of Pi?
I'm currently doing Polar Coordinates with Argand Diagrams, and this is something I'm curious about.
I've just done a question and come out with -0.983 rad. We've left it in decimal form in lectures, but I was just curious to know how I'd go about writing it in terms of Pi.
[tex]45\deg = 0.785 = \frac{\pi}{4}[/tex]
[tex]-56.34\deg = -0.983= \frac{?}{?}[/tex]
Anyone know?
Also, I've always had trouble with angles. Calculus? Love it. Trig? Huh!
Thanks
Mathematics news on Phys.org
[tex]-56.34 deg=\frac{-56.34}{180} \pi [/tex]
So, you have an equation with an unknown? Why can't you solve it?
Thanks for the replies. :smile:
I'd never thought of doing that. I'm actually a bit worried now. I should have known that by now.
Would you happen to know how to convert the -0.983 directly in terms of Pi, without using degrees at any point?
I'm starting to recognise angles in decimal radians, so I figure it would be good to know (and understand) what they are in terms of Pi.
I've just got these from further questions:
[tex]1.047 = \frac{\pi}{3}[/tex]
[tex]0.707 = \frac{?}{?}[/tex]
I've seen the second one before, but I can't remember what it is in terms of Pi.
I'm really sorry, but I don't know what you mean. I can do the questions as I've been shown in lectures. I'm asking about this "conversion" to mostly satisfy my own curiosity. :smile:
Assuming you mean "in terms of Pi radians", I guess you're looking for x*Pi = -0.983, which is straightforward algebra. This gives you about -0.313Pi.
[tex]0.707 \, \text{rad}=x\, \pi \,rad[/tex]
Divide both sides by [itex]\pi[/itex] radians:
[tex]\frac{0.707}{\pi}=x[/tex]
Hello Matty R! :smile:
(have a pi: π and a degree: º :wink:)
Matty R said:
… I've just done a question and come out with -0.983 rad. We've left it in decimal form in lectures, but I was just curious to know how I'd go about writing it in terms of Pi.
You wouldn't! :smile:
Just leave it in radians …
why do you think you need to change it? :wink:
Yes, you most likely saw this one from [tex]\frac{1}{\sqrt{2}}[/tex] :smile:
And tiny-tim has a point. You wouldn't change it in terms of [itex]\pi[/itex] because your answer is obviously approximated and most likely since you had to approximate the answer, it's not going to be a nice fractional radian value such as [itex]\pi/4[/itex] etc.
Yes, 0.707 = cos(π/4) = sin(π/4). :wink:
Wow. Thanks for all the replies. :smile:
I think I see where I got a bit confused. I thought everything could be written in terms of Pi, but its the fractions like [tex]\frac{1}{\sqrt2}[/tex] that I need to be looking at.
I am so bad with angles. Getting better though. :smile:
I love this site.
Thank you all very much. :smile:
Anything can be written in terms of [itex]\pi[/itex], if you like:
[tex]\frac{1}{\sqrt{2}}\,\text{rad}=\frac{1}{\sqrt{2}} \cdot \frac{\pi}{\pi}\,\text{rad}\approx 0.225 \pi \, \text{rad} \approx 0.707 \, \text{rad}[/tex]
Whether you want to just depends on what's most useful or convenient or meaningful, or what kind of answer gives most insight.
FAQ: Writing decimal radians in terms of Pi
1. What is a decimal radian?
A decimal radian is a unit of measurement used to express angles in terms of Pi. It is a decimal representation of the angle in radians, with Pi being equivalent to 180 degrees.
2. How do you write decimal radians in terms of Pi?
To write decimal radians in terms of Pi, you simply divide the decimal by Pi. For example, if the decimal is 2.5, the equivalent in terms of Pi would be 2.5/π.
3. Why is Pi used in writing decimal radians?
Pi is used in writing decimal radians because it is a mathematical constant that represents the ratio of a circle's circumference to its diameter. This makes it a useful tool in calculating angles and other geometric measurements.
4. Can decimal radians be converted back to degrees?
Yes, decimal radians can be converted back to degrees by multiplying the decimal by 180/π. For example, if the decimal is 1.5, the equivalent in degrees would be 1.5 x 180/π = 85.943 degrees.
5. Are there any other ways to express decimal radians?
Yes, decimal radians can also be expressed in terms of fractions or in terms of other mathematical constants, such as Tau (2π). However, using Pi is the most common and widely recognized way to express decimal radians.
17K
38K
