Writting a Circle in a Latex Document
In summary, to add labels above each circle in the given Latex segment of code, use the <code>\node[above] at (node_name.north) {label_text};</code> command for each node.
EngWiPy
1,368
61
Hello,
I have the following Latex segment of code:
Code:
\documentclass[a4paper,12pt,openany,oneside]{memoir}
\usepackage{tikz}
\begin{document}
\begin{figure}
\begin{center}
\begin{tikzpicture}
\pgfsetfillopacity{0.5}
    \draw [very thick,dashed,fill=gray!60](0,0) circle (3.6cm);
    \draw [dashed,fill=gray!20](3,2) circle (3.6cm);
    \draw (0,0) circle (6cm);
    \node (source) at (0,0) [circle,draw] {$S$};
    \node (relay) at (3,2) [circle,draw] {$R$};
    \node (destination) at (6,0) [circle,draw] {$D$};
    \draw [->] (source.60) to node [auto] {} (relay.west);
    \draw [->] (relay.east) to node [auto] {} (destination.120);
    \draw [->] (source.east) to node [auto,swap] {} (destination.west);
\end{tikzpicture}
\end{center}
\end{figure}
\end{document}
I want to write above each circle. How can I do that?
Thanks in advance
.You can add labels to each node like this:\documentclass[a4paper,12pt,openany,oneside]{memoir}\usepackage{tikz}\begin{document}\begin{figure}\begin{center}\begin{tikzpicture}\pgfsetfillopacity{0.5} \draw [very thick,dashed,fill=gray!60](0,0) circle (3.6cm); \draw [dashed,fill=gray!20](3,2) circle (3.6cm); \draw (0,0) circle (6cm); \node (source) at (0,0) [circle,draw] {$S$}; \node (relay) at (3,2) [circle,draw] {$R$}; \node (destination) at (6,0) [circle,draw] {$D$}; \node[above] at (source.north) {Source}; \node[above] at (relay.north) {Relay}; \node[above] at (destination.north) {Destination}; \draw [->] (source.60) to node [auto] {} (relay.west); \draw [->] (relay.east) to node [auto] {} (destination.120); \draw [->] (source.east) to node [auto,swap] {} (destination.west); \end{tikzpicture}\end{center}\end{figure}\end{document}</code>The <code>\node[above] at (source.north) {Source};</code> command adds a label above the Source node. You can do the same for the other nodes. You can adjust the position of the labels by changing the coordinates given in the <code>at</code
for your help!
Hello,
Thank you for reaching out. To write above each circle, you can use the \node command and specify the position of the text using the "above" option. For example, you can use \node (source) at (0,0) [circle,draw,above] {$S$}; to write "S" above the source circle. You can also change the font size and style using the "font" option. Hope this helps!
Related to Writting a Circle in a Latex Document
What is the syntax for writing a circle in a LaTeX document?
To write a circle in a LaTeX document, you can use the command \circle{radius} or \odot for a filled circle.
How do I change the size of the circle in my LaTeX document?
To change the size of the circle, you can add an optional argument to the \circle command, such as \circle[2cm]{radius} to make the circle 2 centimeters in diameter.
Can I add text or symbols inside the circle in my LaTeX document?
Yes, you can use the \put command from the graphicx package to add text or symbols inside the circle. For example, \put(0,0){\circle{1.5cm}} will create a circle with a diameter of 1.5 centimeters and place it at the origin (0,0) on the page.
How do I change the color of the circle in my LaTeX document?
To change the color of the circle, you can use the \color command followed by the desired color, such as \color{blue}\circle{radius} to create a blue circle. Alternatively, you can use the \colorbox command to create a colored background for the circle.
Is there a way to draw a partially filled circle in my LaTeX document?
Yes, you can use the \arc command from the tikz package to draw a partially filled circle. The syntax is \arc[options]{radius}{start angle}{end angle}.
