Wrong analysis in projectile problem
In summary, the archerfish shoots at a target 2.00 m away, at an angle of 30.0o above the horizontal. With what velocity must the water stream be launched if it is not to drop more than 3.00 cm vertically on its path to the target?
IWantToLearn
95
An archerfish shoots at a target 2.00 m away, at an angle of 30.0o above the horizontal. With what velocity must the water stream be launched if it is not to drop more than 3.00 cm vertically on its path to the target?
i have troubles with this problem (Physics for scientists and engineers 6th edition)(Serway, Jewett)
i need to know what is wrong in my analysis
My Answer
target position x=2cos30=1.73 m. , y=2sin30=1 m.
maximum height H=1+0.03=1.03 m.
but H=vi2sin2θi/2g
=> vi2sin2θi=(9.8)(2.06)
the equation of the trajectory is y=(tanθi)x-[g/(2vi2cos2θi)]x2
=> 1=1.73tanθi-[(9.8)(1.5)/(vi2cos2θi)]
substituting for the value of vi2
we get a quadratic equation in tanθ
0.73tan2θi-1.73tanθi+1=0
either θi=54° or θi=45°
hence vi=5.6 m/s or vi=6.35 m/s
this solution is wrong , i don't know why?
the solution manual answer is 25.8 m/s with a different approach in the problem solving
so what is wrong in my solution
Shouldn't that Max Height be 1-0.03 meters = 0.97 meters?
of course not, if the maximum height is 0.97 this means that the water shoot will never get the target which is at height of 1 m.
even trying to substitute for H=0.97 will result in imaginary values for tanθ
you're given an angle of 30 degrees and told that it must not drop more than 3 cm...sounds like 0.97 meters since the question you quoted stated "drop", not rise...but it's your karma...good luck
Hi TxRationalist
i think that you agree with me that the target is at height of 1 m.
and because the problem statement saying that the water drops 3 cm before catching the target, and since the projectile rising then dropping so the maximum height must be larger than the target height , (water falls from the point of maximum height to a distance 3 cm before catching the target)
so the maximum height=target height + falling distance=1+0.03=1.03
more than that i tried your answer for the height to be 0.97 m. and it yeilds imaginary values for tanθ
anyway thanks for your help :)
I'm not saying I'm right, just that that is what jumped out at me as the path to the solution when I looked at it. I ran the numbers and the quadratic equation gave me a negative for "b squared minus 4ac" also. Unless I did something wrong. I'm going to take another look at it.
well, i didn't cancel out the "t" the first time, so that my quadratic equation was in the general form. I corrected that, which led to the form of at^2+c=0. I solved this using my 0.97 m and got a result of 25.7 m/s. Awfully close. I'm going to run it with the same method using your numbers. Just so you know my method, I used the x component of the velocity to solve for V0, substituted this into my Vy equation and solved that t. I then substituted this back into the x/[t*cos(theta)] to get 25.7 m/s
sorry i didn't understood what you did, if you please help me with a complete solution, let me know what is wrong in my solution
many thanks
I broke the problem down into the x and y components:
x = (V0cosθ)t
y = (V0sinθ)t - 0.5gt^2
I used the first equation to isolate V0, substituted this into the second equation and solved for t. I then used the first equation again to get my answer for V0.
Hope this helps, I have to get back to work.
may i am mistaken, but i wonder how you solved two equations for three variables, V0,θ and t
what is wrong in my solution?, this is what makes me go mad
theta = 30 degrees.
Dear TxRationalist
theta that you are mentioning in your equation is not 30°(30° which is the angle the position vector of the target with respect to the fish makes with the horizontal) , in your equations it must be θi not θ, and θi is not given,
even the solution manual saying the same thing
and it calculated θi using a different approach θi=30.7°
anyway thanks for your kindness and your tries to help
Is the wording of the problem exactly as it was given in the book? It's a bit ambiguous, and I wouldn't interpret it the way you have. Was there an accompanying figure you could provide?
unfortunately there is no accompanying figure , and i agree with you that the wording of the problem is ambiguous
anyway here is the complete text of the problem
The small archerfish (length 20 to 25 cm) lives in brackish waters of southeast Asia from India to the Philippines. This aptly named creature captures its prey by shooting a stream of water drops at an insect, either flying or at rest. The bug falls into the water and the fish gobbles it up. The archer-fish has high accuracy at distances of 1.2 m to 1.5m, and it sometimes makes hits at distances up to 3.5 m. A groove in the roof of its mouth, along with a curled tongue, forms a tube that enables the fish to impart high velocity to the water in its mouth when it suddenly closes its gill flaps. Suppose the archerfish shoots at a target 2.00 m away, at an angle of 30.0° above the horizontal. With what velocity must the water stream be launched if it is not to drop more than 3.00 cm vertically on its path to the target?
OK, I think you're interpreting it correctly, and the target is at ##x=(2.00\cos 30^\circ)\text{ m}## and ##y=(2.00 \sin 30^\circ)\text{ m}##.
The mistake you're making is assuming that the maximum height the stream achieves is 1.03 m.
The equation for y(t) is ##y(t) = v_{0_y} t - \frac{1}{2}gt^2##. If there were no gravity, the height of a piece of water would be equal to ##v_{0_y} t##. Because there is gravity, it's actually at a height ##v_{0_y} t - \frac{1}{2}gt^2##. The difference between those two, ##\frac{1}{2}gt^2##, is the distance it has fallen. That's what you want to set equal to 3.00 cm.
Note that the water could still be on its way up when it has fallen 3.00 cm. That's why you can't assume the water reaches a height of 1.03 m.
how come!?
me too think that i have troubles with the maximum height , but the wording of the problem let me think that fallen means going from the point of maximum height to the point where the target exist
IWantToLearn said:
how come!?
What integral is saying is that the amount the projectile has "dropped" is the difference in height between the linear trajectory that the projectile would take if there had been no gravity, and the parabolic trajectory that it instead takes in the presence of gravity.
So as soon as it is launched, it begins to "drop" relative to this straight path.
See the attached figure
http://img542.imageshack.us/img542/9411/dropp.jpg
aha
i understand now what "vela" and "cepheid" mean
and this means that i can't make any assumption about the maximum height, water may hit the target before the maximum height or after the maximum height, i think what confused me is that the word "drop" which seems to me very confusing (i should understand that it is a drop from the straight line path without gravity)
now i can get θi from the larger triangle it θ=tan-1 (1.03/1.73)=30.7°
now i can solve the equations for the time t and the initial velocity vi
its clear now :)
many thanks guys, i think i was't smart enough to interpret the problem statement
By the way the authors of the book avoided this problem in 7th and 8th editions of the book
IWantToLearn said:
aha
its clear now :)
I think that the problem statement was hard to interpret. It wasn't your fault. I didn't think that's what they meant by "drop" either until Integral brought it up. You should try solving the problem under this assumption and seeing if you get the right answer.
i did, your interpretation is right, and i got theta from the geometry as i mentioned above and i was able to get the same solution exactly as the solution manual
Related to Wrong analysis in projectile problem
1. What is a projectile problem?
A projectile problem is a type of physics problem that involves an object being launched or thrown into the air and then traveling in a curved path due to the force of gravity. Examples of projectile problems include throwing a ball or shooting a bullet.
2. Why is it important to analyze projectile problems correctly?
Analyzing projectile problems correctly is important because it allows us to accurately predict the motion of the object and understand the underlying physics principles at play. Incorrect analysis can lead to inaccurate predictions and conclusions.
3. What are some common mistakes made in analyzing projectile problems?
Some common mistakes in analyzing projectile problems include neglecting air resistance, using the wrong equations or formulas, and not considering the effects of external forces such as wind or friction. Another mistake is assuming that the object will always follow a parabolic path, when in reality it may follow a different trajectory depending on the initial conditions.
4. How can one avoid making mistakes in analyzing projectile problems?
To avoid making mistakes in analyzing projectile problems, it is important to thoroughly understand the relevant physics principles and equations. It is also helpful to double-check all calculations and consider any external forces that may affect the motion of the object. It can also be beneficial to break the problem down into smaller parts and analyze each part separately.
5. What are some real-life applications of projectile problems?
Projectile problems have many real-life applications, such as predicting the trajectory of a ball in sports, understanding the path of a rocket or missile, and calculating the range of a projectile in military operations. They are also used in engineering and design, such as in the construction of bridges and buildings.
