mzu
- 10
Hi,
Hopefully someone can help. I was some pretty simple code to make a H-R Diagram in wxMaxima. The Absolute magnitude on the H-R Diagram should go from 20 to -15. wxMaxima only allows me enter the Y-axis range from -15 to 20 so the values on this axis are the other way around. I can draw the diagram from -15 to 20 and then go into the GNU Plot command line and change the values from 20 to -15 and re-plot from within GNU Plot. I was wondering if it possible to do this from wxMaxima directly so I don't have to change this afterwards all the time. I hope the explanation is a little clear. Here is the code:
Stars: [[0.63,4.8],[0,1.4],[0.15,-2.5],[1.23,0.2],[0.71,4.4]];
load(draw);
draw2d(
xrange=[-0.3,2.2],
yrange=[-15,20],
points(data),
title = "HR Diagram",
xlabel = "B-V",
ylabel = "Absolute Magnitude");
As you can see the yrange goes from -15 to 20. If I enter 20,-15 I get an illegal error. Most of the times it is correct to have the yrange from min to max but on the H-R Diagram it has to be the other way around. Again, this can be done in the GNU Plot command line but I was wondering if this can be done from wxMaxima directly.
Thanks in advance for any help,
Michael
load(draw);
draw2d(
xrange=[-0.3,2.2],
yrange=[-15,20],
points(data),
xlabel = "B-V",
Michael
