X^2+2 were integrated it would be 1/3x^3
  • Thread starter Thread starter defineNormal
defineNormal
Hello I'm trying to integrate Ar^(1/2)
would the answer be?
well I know if X^2+2 were integrated it would be 1/3x^3
I just get confused when it's fractions would it be
(3/4)Ar^(3/2)?
You're close.. just the factor infront is incorrect. From your example, you know that the general rule is \int x^n dx = \frac{1}{n+1} x^{n+1} + C Try and fit your specific case into this, and you should come out with the correct constant in front.
It depends what you are integrating with respect to. Are you integrating with respect to r?
You forgot to integrate half of that function, your answer would be correct for integrating just x^2 but you didn't integrate the 2.
(3/4)Ar^(3/2)?
If you are integrating with respect to r then this is almost correct, but your fraction isn't quite right. What is the rule when you integrate x to a power?
well it's A*r^(1/2), for example a+bt+bt^2= a^2/2*bt^2/2*bt^3/3, I'm just not good w/ fractions, would it be Ar^(3/2)/(3/2)? or (3/2)Ar^(3/2)?
You're correct with Ar^(3/2)/(3/2) but you need to add the constant of integration, so the solution is (2/3)*Ar^(3/2) +C
You are takinb calculus and you are telling us you cannot add 1+ \frac{1}{2}?? Am I misunderstanding this?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply . Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
