X and Y coordinates of an oscillating object on a spring.
The discussion centers on the oscillation of an object on a spring, specifically the equations x(t) = A cos(ωt + φ) and y(t) = A sin(ωt + φ). The solution manual claims that when the phase angles φ1 and φ2 are both zero and the amplitudes A and B are equal, the mass moves in a circle centered at the origin. This claim is challenged, as it is argued that at t = 0, the motion should be purely along the x-axis, suggesting no initial displacement in the y-direction. However, it is clarified that initial velocity can lead to y-direction motion, and the circular motion can be mathematically proven by examining the expression for x² + y² under the given conditions. The conversation emphasizes the importance of initial conditions in determining the motion's nature.
phantomvommand
Consider a mass m on a table attached to a spring at the origin with zero relaxed
length, which exerts the force
F = −kr
on the mass. We will find the general solution for r(t) = (x(t), y(t)) in two different ways.
(a) Directly write down the answer, using the fact that the x and y coordinates are independent.
(b) Sketch a representative sample of solutions. What kind of curve does the trajectory follow?
##m\ddot x = kx## solution is ##x(t) = A\cos(\omega t + \phi)##
##r^2 = x^2 + y^2##
I get that:
##y(t) = A\sin(\omega t + \phi)## (from the above relevant equations). This agrees with the solution for part (a).
However, the solution manual claims in part (b) that:
In the case where ϕ1 = ϕ2 = 0 and A = B, the mass moves in a circle centered at the origin.More generally, when the angles ϕi are unequal, the mass can move in an ellipse with centerat the origin.
Is there any way to prove this, or explain this physically? I am especially dubious of the claim that when ϕ1 = ϕ2 = 0 and A = B, it is a circle, because this situation, physically, at time t = 0, should represent a simple 1D motion along the x-axis, since the spring was never stretched in the y-direction to begin with!
except that, as indicated later, the amplitude and phase constants can be different. Only the frequency must be the same.
Easily proved. Write down the expression for ##x^2+y^2##.
Slight variation for the ellipse case.
You don’t know that, but it’s not just a question of initial displacement. In the general case, it may have been given some initial velocity.
Likes phantomvommand
In first instance this is math. You have two seond order differential equations, so four initial conditions.
For example ##x, \dot x, y, \dot y## at ##t=0##.
Or ##A, \phi_1, B, \phi_2## at ##t=0##.
Setting
leaves only one degree of freedom. And sure enough the "choice"
##x = A \cos(\omega _t),\ \ y=\sin(\omega t)## describes circular motion,
with very specific initial conditions ##x=A, \dot x=0, y=0, \dot y=\omega A## at ##t=0##
Ah, hello @haruspex !
So: no! Spring not stretched in the ##y## direction at ##t=0## doesn't mean never stretched. ##\dot y \ne 0## at t=0 means it does gets stretched in the ##y## direction.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
