X intercept of Line Tangent to Curve
In summary, the x-intercept of the line tangent to the given curve at t=1 is x=2. This can be found by using the parametric equation of the tangent line, L(s) =<x(s), y(s)> and setting y(s) = 0. This results in s=0 and therefore x=2.
mill
72
What is the x-intercept of the line tangent to the curve x(t) = 3 + cos(∏t), y(t) = t^2 + t + 1, when t = 1?
Derivative, y=mx+b
To find the line tangent to the curve:
d/dt = <-∏sin(∏t), 2t+1>
at t=1 <-∏, 3>
dy/dx = dy/du * du/dx = -3/∏
y=(-3/∏)x+b
at t=1, <x,y>=<3,3>
y-3 = (-3/∏)(x-3)
y = -3x /∏ + 9/∏ +3
To find x-int. set y=0 so 0=-3x /∏ + 9/∏ +3
(-3 - 9/∏)(-∏/3)=x
The answer is x=2. I am not sure where I went wrong.
Derivative, y=mx+b
at t=1 <-∏, 3>
##\sin(\pi)=0##
What is ##u##? I think you mean ##\frac{dy}{dx}=\frac{\frac{dy}{dt}}{\frac{dx}{dt}}##. But you could just use the parametric equation of the tangent line instead of using ##y=mx+b## form.
y=(-3/∏)x+b
at t=1, <x,y>=<3,3>
y-3 = (-3/∏)(x-3)
y = -3x /∏ + 9/∏ +3
(-3 - 9/∏)(-∏/3)=x
LCKurtz said:
##\sin(\pi)=0##
I see sin(∏)=0. Then that would mean dy/dx = 0.
By parametric equation of the tangent line do you mean r'(t)=x' + y'? To find int. I would set r'(1)=x' + y' and x'=-∏sin(t∏). t=1 so x'=-∏sin(∏)=0. y'=3
x'=sin(∏)=0 Inv sin (0)=0
r'(t)=3
No. The 0 is in the denominator, so the slope is undefined. All the more reason not to try using ##y=mx+b##.
r'(t)=3
That is really poor notation. ##r(t) = \langle x(t),y(t)\rangle## which is a vector, not a sum, and ##r'(t) = \langle x'(t),y'(t)\rangle## so ##r'(1) = \langle -\pi\sin\pi,3\rangle=\langle 0,3\rangle##. Since ##r(1) = \langle 2,3\rangle##, you have a point and direction vector for the tangent line when ##t=1##. What is the parametric equation of that tangent line?
Would it be r(t)=<0, 3> + t<2,3> for the tangent? I am not sure how I can say the intercept is two from this equation. If I just look at x then x=2t which at t=1 is 2. Is that how it is found?
Close but you have it backwards. <2,3> is the point and <0,3> is the direction vector. And it's best to use a different parameter and a different name so ##L(s) = \langle<x(s),y(s)\rangle=\langle 2,3\rangle + s\langle 0,3\rangle ##, where ##L## is the tangent line.
What value of ##s## makes ##y(s)=0##? What is ##x(s)## for that value.
Also, try not to lose sight of the forest for the trees. In the xy plane you have a line through (2,3) and its direction vector is <0,3>. What direction is that? What does the line look like?
s would need to be 0. Would I necessarily need to find y in order to find the x-intercept?
The point (2,3) is going towards (0,3) so it is a line headed downwards along x?
mill said:
##s## would need to be 0.
Why?
The x intercept on any graph is the x value when y = 0.
I don't know what "(2,3) going towards (0,3)" means nor what "headed downwards along x" means. The graph is a straight line. Surely you can describe it better than that. Plot a few points for various s.
LCKurtz said:
Why?
If I separate them into x=2+s(0) and y=3+s(3) then the only thing that makes y=0 is s=0?
Are you serious?
LCKurtz said:
Are you serious?
If I weren't, I wouldn't still be here eight hours later, sadly. Going off your equation L(s) =<x(s), y(s)> I assumed that I can simply look at x(s) since it is the x-intercept. s=0 so x=2. If I'm missing something, I don't know what it is.
You have y = 3+3s and you are saying y = 0 when s = 0?
In this problem x happens to be constant so x=2 is the correct intercept even though you have the incorrect value of s for y=0. Can you describe what the line looks like?
FAQ: X intercept of Line Tangent to Curve
What is the X intercept of a line tangent to a curve?
The X intercept of a line tangent to a curve is the point where the line intersects the X axis. This point is also known as the point of tangency.
How is the X intercept of a line tangent to a curve calculated?
The X intercept of a line tangent to a curve can be calculated by finding the derivative of the curve at the point of tangency and setting it equal to the slope of the line. Then, solving for the X value will give the X intercept.
Why is the X intercept of a line tangent to a curve important?
The X intercept of a line tangent to a curve is important because it represents the point where the slope of the curve is equal to the slope of the line. This point can provide valuable information about the behavior and characteristics of the curve.
What does the X intercept of a line tangent to a curve tell us about the curve?
The X intercept of a line tangent to a curve can tell us about the concavity of the curve at that point. If the X intercept is positive, the curve is concave up, and if it is negative, the curve is concave down. It can also tell us about the direction of the curve at that point.
Can the X intercept of a line tangent to a curve have multiple values?
Yes, the X intercept of a line tangent to a curve can have multiple values if the curve has a point of inflection. In this case, the curve changes concavity and the X intercept can have different values on either side of the point of inflection.
